Question of the Week: Are aluminum body panels on the 2015 F150 a good idea? - Ford Truck Enthusiasts Forums
2015+ F150 Discuss the 2015 Ford F150 SPONSORED BY:
View Poll Results: Are the aluminum body panels on the 2015 Ford F150 a good idea?
Yes, Ford wouldnt screw up the F150. 33 84.62%
No, Aluminum just cant be tough enough. 2 5.13%
I cannot decide until I see them on the road, facing abuse. 4 10.26%
Voters: 39. You may not vote on this poll
Old 07-25-2014, 05:17 PM
Patrick R. Patrick R. is offline
Patrick R. is starting off with a positive reputation.
For the first installation of our new Question of the Week segment, we want to know if you think that Ford made a good move by going with aluminum body panels on the next generation F150?
Even though the 2015 F150 hasnt hit the streets yet, we want to know if you like the idea of the aluminum body panels so vote in the poll above and explain why you feel this way in the comments below!
Old 07-26-2014, 01:27 AM
j.grif's Avatar
j.grif j.grif is offline
j.grif has a very good reputation on FTE.j.grif has a very good reputation on FTE.j.grif has a very good reputation on FTE.j.grif has a very good reputation on FTE.
Lighter stronger materials mean more durable and more fuel efficient, with higher resale, they say airplanes use aluminum, but airplanes don't get door dents (not the same as hanger rash), corrosion can be an issue if moisture is not kept at bay in the floor and structural low areas, if you work in a truck fleet, you know what I mean, but I think that with Fords experience with Range Rover, I think they know a thing or two about the required practices regarding separating dissimilar metals and not creating a battery! Working with semi trailers, the biggest corrosion areas seem to be at the panel to frame tie ins, particularly bad with insulated reefer trailers because the insulation in them is a sponge after year nine and you get moisture drive like crazy, but we do run these aluminum trailers through 17 years before we scrap them, in many cases still running and useable. I think with proper care on the end users part this should be a good thing. Detroit area.
Old 07-26-2014, 01:31 AM
Frdtrkrul Frdtrkrul is offline
Frdtrkrul has a good reputation on FTE.Frdtrkrul has a good reputation on FTE.Frdtrkrul has a good reputation on FTE.
Look at USPS vans they have been using for years with aluminum bodies...even big Snap-On tool trucks are aluminum. Its been proven to be a very good material. Yes it'll have a bit more cost to it for painting and repair.
I personally like steel better. Easier to work on and repair. But aluminum does not rust away like steel. Eventually they'll have to reduce weight even more to meet the 2025 CAFE regs for 54.4mpg for trucks.
Old 07-26-2014, 06:35 AM
tseekins's Avatar
tseekins tseekins is offline
tseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputation
Welcome Patrick! Please identify yourself as you used the word our for your poll. I'm curious if you're doing this poll on your own or for a company.
Thank you for your prompt response.
Old 08-15-2014, 08:41 PM
cwayne cwayne is offline
cwayne is starting off with a positive reputation.
oxidation
Aluminum is a great idea.. Strength and durability, I don't see an issue.. However, areas of steel to aluminum will be a problem in the long term. In the north where salt and calcium chloride are used to clear roads in the winter, nothing but devastation to the aluminum.. I own and operate a body shop and deal with this nightmare of corrosion constantly..Steel rots quick enough..I don't know the answer to prevent this problem, but I do a lot of rustproofing sprays and it does help.. But, it is not foolproof..
Weight reduction for fuel saving is great. Little dents are common in steel sheetmetal from the shoppers who find it necessary to slam their doors into the side of anything within a 100 feet..So, dents won't change, being steel or aluminum...
God knows we need some fuel economy...
Old 08-16-2014, 03:11 PM
efx4's Avatar
efx4 efx4 is offline
efx4 is gaining momentum as a positive member of FTE.efx4 is gaining momentum as a positive member of FTE.
Aluminum that has been properly prepped, primed and painted should do well, especially thicker aluminum alloy that the F-150 will use. Keeping it properly separated from steel; like by e-coat between the 2 dissimilar metals, should be a minimum effort to hopefully prevent galvanic reaction. At the autobody end, proper prep with body hammers, sanders, etc. should be aluminum specific and not contaminated with any steel. Aluminum is certainly not a new metal in automotive applications, it's just being used in greater amounts in todays vehicles, and proper repair must be observed. That's probably a hurtle that must be dealt with when these trucks ultimately end up in a collision shop at some point.
Old 08-16-2014, 03:59 PM
GuyGene's Avatar
GuyGene GuyGene is offline
GuyGene is gaining momentum as a positive member of FTE.
I love it! I think most makes will do this soon. Ask my 60 year old DuraCraft log busting, rock bumping sand scraping boat.
Old 08-18-2014, 11:46 PM
1saxman's Avatar
1saxman 1saxman is offline
1saxman is gaining momentum as a positive member of FTE.1saxman is gaining momentum as a positive member of FTE.
All I know is my 2007 has an aluminum hood, and its covered in dents from small limbs falling out of my trees and the occasional hailstone. Do I think its a good idea? Yes, I do, but I also think it may be a little ahead of its time. I foresee this move becoming another 'Edsel' in Ford's history. I have more reservations about the aluminum bed than I do about the cab. On the other hand, a 700# lighter truck combined with a turbo V6 would be very attractive to me. I'm getting tired of my rather mild V6 manual but there is no new truck in my financial plan and I only have 16K on the '07, so I guess it'll be around for some time. Who knows? Low miles steel trucks in great condition just may become more valuable soon.
Question of the Week: Thoughts on the aluminum F150 after two years Patrick R. General Automotive Discussion 1 09-24-2016 10:34 AM
F-150: Aluminum Ford Trucks Official Ford Forum : Ask an Engineer 18 08-12-2016 07:10 PM
Question of the Week: Should Ford wait to use aluminum on the Super Duty body? Patrick R. 2017 Super Duty 12 03-17-2015 09:30 AM
Question of the Week: Are the concerns about the 2015 F150 overblown? Patrick R. 2015+ F150 17 12-16-2014 04:02 PM
If F150 Body Panels are Tough, Is Aluminum a problem? ncalf150 2015+ F150 9 07-23-2014 06:11 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
