Tire pressure - Ford Truck Enthusiasts Forums
Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Tire pressure
Old 07-25-2014, 04:59 PM
claycomotrucks1991's Avatar
claycomotrucks1991 claycomotrucks1991 is offline
claycomotrucks1991 is starting off with a positive reputation.
Tire pressure
Just got some new Michelin lattatude tour tires on 2010 Escape 235/70-16 to replace older set ,what tire pressure you guys run the dealer put 36-37 cold psi but I was running 35 psi on the old sit and got 75,000 miles out of them!
Old 07-25-2014, 07:05 PM
scott91370 scott91370 is offline
scott91370 is gaining momentum as a positive member of FTE.scott91370 is gaining momentum as a positive member of FTE.
That's too high.
Look at the door jamb, that's what I always go with. Every set I have put on the Tribute has gone over 60k, the factory made it to 75 or 80 if I remember correctly.
Old 06-07-2015, 04:14 PM
SCUDDOG's Avatar
SCUDDOG SCUDDOG is offline
SCUDDOG is starting off with a positive reputation.
Question What about a tad bit more?
Gents,
What about inflating to 2 lbs over the suggested/recommended tire pressure as stated on the door jamb? My 2014 Escape calls for 35 lbs... an interesting pressure because that pressure is usually what any tire shop defaults to when inflating tires.
For years and years I have been following the door jamb or in some cases glove box pressure recommendations plus 2 lbs. My theory is that it is not too much of an impact on ride stiffness and it can only help economy. Arguments can be made that it could compromise wet braking of course.
What do you guys do? A tad bit over? Follow the exact PSI? Something else?
Old 06-08-2015, 07:23 AM
jbtecnico1 jbtecnico1 is offline
jbtecnico1 is starting off with a positive reputation.
I do door jamb plus 2lbs regularly, check it every month, early morning.
Running Michelin LTX MS2 on my Exped, F150 and Escape.
The real trick is to find a gauge that you can trust.
I use a cheapo mechanical type with 0-50psi range for easier reading and dialing it in. I replace that gauge every year or so, or when the psi slider gets "sticky"...
So far so good for performance, tire wear and life span.
Old 06-08-2015, 07:53 AM
wptski wptski is offline
wptski is starting off with a positive reputation.
The crazy Escape Hybrid owners run 50-55psi and think it's great. That kind of pressure would beat me to death on my local roads.
Old 06-08-2015, 07:57 AM
Tedster9's Avatar
Tedster9 Tedster9 is offline
Tedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputation
Wheel bearings too
Tire Pressure Questions Optimistic Paranoid Brakes, Steering, Suspension, Tires, & Wheels 7 11-16-2015 10:28 PM
Another tire pressure question Matthew Barnes 1999 to 2016 Super Duty 9 11-14-2015 06:58 AM
Amazed at tire pressures affect on MPG jayro88 1968-2013 Full Size Vans 22 08-19-2015 05:59 AM
Air pressure claycomotrucks1991 Brakes, Steering, Suspension, Tires, & Wheels 1 07-27-2014 02:43 PM
Low Tire Pressure warning 2011 F 350 richhrub 1999 to 2016 Super Duty 4 02-19-2014 07:37 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
