Need part numbers for blend door actuators
Old 08-03-2014, 03:20 PM
mdt623's Avatar
mdt623
mdt623 is offline
Hello there. I need help locating the right part numbers for the rear blend door actuators for my 2005 Explorer XLT. I had the thumping coming from the rear of the vehicle, and from experience with my previous explorer I knew it was the blend door actuator. I actually replaced the front one on my previous explorer. So I tore into the back and extracted the two actuators to replace them both. I figure that since I was there I should do them together. I pulled them so I could get the exact replacement rather than have to guess and hope. I can find the replacement for one that I am confident with, but the other seems to be a challenge. Here is what I have discovered.
The one I can find replacement for has the model number on it of 2L2H-19E616-AA. This one has the cross shaft. My research has led me to understand that the following are the replacements
Motorcraft YH-1743
Dorman 604-209
dealer replacement is 1L2Z-19E616-BA
My problem lies in finding the replacement for the other one which has the model number 2L2H-19E616-BB. This one has the D-shaft. Can anyone help me track down the proper replacement model numbers for this item.
Thanks
Old 08-05-2014, 04:01 PM
mdt623's Avatar
mdt623
mdt623 is offline
When I posted this it was on Sunday and I could not contact the dealership. I have since made contact with my local dealership and I have the part numbers. I will post them here in case anyone else is looking for them.
2L2H-19E616-AA is confirmed through the dealership as Motorcraft YH-1743
2L2H-19E616-BB is confirmed through the dealership as Motorcraft YH-1746
Hope this helps someone else out.
Old 08-08-2014, 08:49 PM
steve(ill)'s Avatar
steve(ill)
steve(ill) is offline
badltl510
1997-2006 Expedition & Navigator
08-21-2008 12:19 AM
scucci
10-16-2007 03:09 PM
adgillis
1999 to 2016 Super Duty
12-05-2005 05:06 PM
jbowling
10-07-2004 01:16 PM
Quick Reply: Need part numbers for blend door actuators
