351w - HP and Torque estimation after build????
Hey guys, I've been lurking in the shadows for a couple years now. Used to have tons of time to modify and fix my old trucks but work family and new house got my time...
Anyhow I'm back to my pulling truck build. "Zeus" below... 351w build zf542 3.55 gears 4x4
Here is what's been done so far.
1.) .030 over bore flat top hypertunic pistons 9.5-9.8 compression ratio
2.) Headman LT headers
3.) Comp cam 35-255-5 (sad motor so I couldn't go to crazy)
4.) No cats and high flow exhaust. Probably 2.5" single. Not for sure yet on exact configuration yet but will be way more open than stock
5.) stock rebuilt heads
Pretty simple build, just want to know where my power numbers might be. Hoping Paul (conanski) might chime in here. Pretty sure I had some #'s on this setup before but can't find all my old info and forgot 1/2 of what I learned.
I have considered the gt40 heads but they have been hard to find at junk yarss here and not sure if that would overload the SD computer. Would be willing to trade some 300 i6 performance parts if anyone has some heads and they would work for me... I have dual plane offey intake, 390 4bbl holly carb, efi manifolds and a hotter cam and lifter kit.
Yea I'm pretty sure that was the #'s I'm remembering. A couple years back when I was doing the engine build I was looking for the upgrades that would work with the SD computer to get more power. I got the higher domed hypertunic pistons when I did the rebuild b/c I believe you suggested it to bump the CR in the engine. From what I recall the stock CR was like 8.5:1? I know the new estimated CR with the pistons I bought was at least 9.1:1 or higher.
on
The higher the CR and the heavier the vehicle the more difficult it is to prevent detonation. With a gas truck that will likely have oversized tires and fuel milage focused gearing and possibly see duty towing loads the practical limit for CR is around 9.5-10:1 with available pump gas, but even at the upper limits of that the thing would likely be a premium fuel only vehicle without a really fancy ignition control system.
eriklane
10-25-2015 10:41 AM
abninf87
09-21-2009 10:17 PM
DVM04
02-25-2007 08:38 AM
Critter
22
03-02-2004 07:14 PM
mnm1997
21
03-18-2001 12:37 AM
