1972 F-250
Old 07-25-2014, 02:29 PM
quinletc's Avatar
quinletc
quinletc is offline
1972 F-250
Guess if I had thought about it, I would have started with this title, and then the thread would have just built on itself over time. Oh well...
Wheels. It seems I have split rims. While I understand these are original equipment, I am hearing that many tire shops won't mount tires on them.
Do they present any danger when airing up - I mean just adding air occasionally?
I assume that as long as I get new wheels with a 8x6.5 lug pattern, I can switch to solid wheels. Correct?
Any recommendations on where to get basic steel wheels?
Old 07-25-2014, 02:34 PM
qman's Avatar
qman
qman is offline
Junkyard is full of them
Old 07-25-2014, 03:01 PM
HIO Silver's Avatar
HIO Silver
HIO Silver is offline
2x.. Econolines would be the preferred donors... 16x7.
Old 07-25-2014, 03:33 PM
quinletc's Avatar
quinletc
quinletc is offline
Thanks! Great to know about the Econolines, as websites keep pointing me to 16.5" rims, and the tire selection for those is much smaller.
Old 07-25-2014, 03:37 PM
HIO Silver's Avatar
HIO Silver
The yards I go to have TONS of retired Econolines since they are more or less working and delivery vehicles these days. Potential donors are up to the mid-90s if I recall correctly.
Old 07-25-2014, 06:48 PM
RichS2659's Avatar
RichS2659
RichS2659 is offline
HIO, for Econo wheels it would be up to 2013 as the Econo's still used the Dana 60 with the 8x6.5 pattern. The regular Econo is dead. They might have gone to 17" in the last few years.
Old 07-25-2014, 07:02 PM
JEFFFAFA's Avatar
JEFFFAFA
JEFFFAFA is offline
FYI. Econolines still show 16" in 2014 model year.
Old 07-26-2014, 03:44 AM
jowilker's Avatar
jowilker
jowilker is offline
quinletc The wheels became quite a hazard when reloading a new tire. There have been several men that have been killed and or badly maned when the wheels would blow apart when refilling them with air. As posted replacements should be common to find from 3/4 ton and up trucks
I believe you will have more tire choices available to you in 16" rather than 16.5.
John
Old 07-26-2014, 08:09 AM
quinletc's Avatar
quinletc
quinletc is offline
Again, thanks for all the info - very helpful.
Incidentally, I've been watching the new season of Falling Skies, and there are a bunch of 70's and 80's F-series trucks in the show.
Old 07-26-2014, 02:41 PM
quinletc's Avatar
quinletc
quinletc is offline
Yellow Primer?
There are a few spots on the hood where yellow is showing through the old, weathered red paint.
Is the yellow actually primer? The hood and paint are allegedly original.
Old 07-27-2014, 11:34 PM
orich's Avatar
orich
orich is offline
It could be the hood was replaced at one time. Many thinks happen in 40+ yr old vehicles. Most were dark primers used.
orich
Old 07-28-2014, 07:18 AM
nkf's Avatar
nkf
nkf is offline
I'd check with a dealer and see what new ones go for. Around here new wheels are about $10.00 more over used. Or look for new steel after market wheels too. The tire shop I go to all the time has like new steel wheels for not a lot of money as well. Let your finger do some walking before heading to a bone yard.
Old 07-29-2014, 09:17 PM
tsoza86's Avatar
tsoza86
tsoza86 is offline
I work in a tire shop and Im one of the few that will do.split rims. Voming fron my experience your better off buying different rims 16.5 tire are expendive and limited and you can get plain black or steel wheels for cheap
Old 08-02-2014, 01:35 PM
quinletc's Avatar
quinletc
quinletc is offline
Lug size
What size are the lugs on a '72 F250 with 8 lugs? Was there more than one size?
Old 08-04-2014, 02:19 PM
JEFFFAFA's Avatar
JEFFFAFA
JEFFFAFA is offline
The studs are 1/2" X 20. The nuts are the same as F100's and cars back then. From memory I'd saw 13/16" socket.
Quick Reply: 1972 F-250
