1972 F-250 - Page 2 - Ford Truck Enthusiasts Forums
1972 F-250
Old 08-04-2014, 03:22 PM
orich's Avatar
orich orich is offline
orich has a great reputation on FTE.orich has a great reputation on FTE.orich has a great reputation on FTE.orich has a great reputation on FTE.
Quote:
Originally Posted by JEFFFAFA View Post
The studs are 1/2" X 20. The nuts are the same as F100's and cars back then. From memory I'd saw 13/16" socket.
I was going to answer this but it was to easy since all f-100's & f250's were same same by 13/16" same a the spark plugs used for these..
orich
Old 09-05-2014, 10:07 AM
quinletc's Avatar
quinletc quinletc is offline
quinletc is starting off with a positive reputation.
I feel like I should record everything I've done, before I forget. So far, I have:
1. Covered the seat. Just a saddle-blanket cover, not a re-cover.
2. Installed 3-point seatbelts
3. Found one-piece wheels, painted them, got new tires, and sold the old tires and wheels.
4. Replaced fuel tank sending unit float and gasket.
5. Replaced temperature sending unit (and some of the coolant as a result).
6. Replaced the windshield washer hoses.
7. Replaced a bunch of bulbs - was thrilled that it was all bulbs and no bad wiring.
8. Installed cigar lighter.
9. Repaired floor pans.
10. Replaced windshield and gasket - finally, something someone else paid for. Glass coverage is my friend. (I know, I paid for it already, but it was nice to not have to pull out my wallet at the glass shop.)
Coming soon to a driveway near you:
1. Install new shocks.
2. Install dash cover.
3. Reseal drip rail.
4. Repair holes at bottom corners of doors.
Old 09-08-2014, 02:00 PM
quinletc's Avatar
Need some help. Truck starts fine and drives fine. Getting out of the driveway takes a little coaxing. We can start the truck and let it run in the morning for a minute or two, but when we first put it in drive (or reverse) it stalls. And it might do this a couple of times.
Once it's going, there's no problem. Pre-tuneup, it would stall at stops, but that's not a problem now.
Is there something we are not doing in the start-up/warm-up sequence that we should be doing? Is there a choke adjustment that might help?
Old 09-08-2014, 07:17 PM
orich's Avatar
I'd Set air/fuel jets screws with vacuum gauge for highest reading. For a Auto tranny idle in D 550 rpm.
If idle to low it will stall.
The Plugs gap 0.34, The dizzy timing 6* BTDC. The points with points .017 unlessit's got the cail. smog crap then .021. Also check that vacuum advance is in good and not leaking sucking air.
orich
Old 09-08-2014, 07:40 PM
JEFFFAFA's Avatar
JEFFFAFA JEFFFAFA is online now
JEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant future
Sounds like choke needs adjustment. Next time you go to drive it remove the air cleaner lid. Start it up as you usually do. To protect you from burning carb backfires, use something like the eraser end of a pencil. Slowly close and/or open the choke flap just a tad by pushing on it with the pencil. In one of the 2 directions see if the idle raises a bit. Adjust the choke to match. 2X Orich on his advice.
Old 09-10-2014, 12:38 AM
quinletc's Avatar
Damnation! The nuts and bolts on the front shocks were rusted something fierce. I hosed them down with WD40 penetrating spray several times, and it was all I could do to get them off. The top ones were the worst. I ended up grinding them off on both sides:
The bottom ones were pretty tough too, though. Had to have my daughter bang on the Vice-Grips with a rubber mallet to get the first one loose. In the end, though, we got the new Monroe Gas Magnums (34900's) in:
It was too late to do the rear by the time we got these in, but I took the truck for a quick spin, and the difference was AMAZING. I mean, I knew it would ride better, but it rides a ton better. And the rear is still to come.
Old 09-10-2014, 08:16 AM
orich's Avatar
Yep those can be a real knuckle buster..
But, I've got see more things for you to change out. As, I look at your pictures your brake hose those rubber lines. I would not trust much longer. Looks pretty bad and like what came on the truck when new..
Orich
Old 09-10-2014, 08:40 AM
quinletc's Avatar
Orich
Aren't you a ray of sunshine this morning!
I am sure you're right about them being 42 years old. The PO was a shade-tree mechanic (not that I am not one also), and he made some odd decisions about what to change and fix and what not to. He also employed some questionable improvised techniques. But overall, the truck runs (and stops) just as it is supposed to.
All that said, I guess I'm adding brake lines to the list.
Old 09-10-2014, 08:48 AM
jowilker's Avatar
jowilker jowilker is offline
jowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to behold
Can you say bucket list?
John
Old 09-10-2014, 08:55 AM
quinletc's Avatar
Quote:
John
If you're implying that the list will not be completed before I am dead... yeah, that sounds about right.
Old 09-10-2014, 02:53 PM
rews2 rews2 is offline
rews2 is starting off with a positive reputation.
Orich
After just doing my front pads my old rubber lines are sketchy at best. Where or who do you get your metal lines through?
Old 09-10-2014, 04:15 PM
jowilker's Avatar
No sir, not at all, Bucket list is a fairly new term for a list of things to do.
John
  #28
Old 09-10-2014, 07:04 PM
JEFFFAFA's Avatar
Orich
2X Orich! Holy Cow TQ! I can see the 1st hard panic stop bursting fluid out where that rusted metal collar meets the rubber hose. We'd like to see ya sticking around ABOVE ground. Please change these ASAP. Check all metal lines also for rust.
  #29
Old 09-10-2014, 07:11 PM
JEFFFAFA's Avatar
Quote:
Check with Inlinee Tube. See if they got 'em.
Tech Support 586. 532. 1338
www.Inlinetube.com
  #30
Old 09-10-2014, 11:07 PM
quinletc's Avatar
I think I just narrowly avoided disaster.
Daughter was pulling in the driveway and says, casually, "Daddy, the engine is smoking a little."
Of course, I was yelling, "TURN IT OFF!"
Steam comes billowing out the grill, and I think she's burned it up for sure. After it quiets down and I've pushed the truck up into my driveway, I take a look, and it seems she didn't run the coolant all out. The oil is still amber. I think Harriet will live to ride again.
It seems the little pin-hole I noticed last week was really the start of a 2 inch crack in the leading edge of the radiator, where the metal is turned up. I washed it off, scrubbed it, cleaned it, dried it, and slathered the whole area with JB Weld.
Going to give it at least 15 hours to cure before re-filling and starting her up again.
OK, so brake hoses are at the top of the list.
17" 18" 20" Wheels - ????? duckduke 2017 Super Duty 30 12-20-2016 09:35 PM
63 f250 4x4 2 piece wheels White squirrel 1961 - 1966 F-100 & Larger F-Series Trucks 19 06-11-2016 12:48 PM
2011 f350 TPMS Question bdavis1369 1999 to 2016 Super Duty 4 11-29-2015 02:51 PM
Wheels/Tires 52flatheadf1 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 07-29-2015 06:16 PM
Wheels for 1962 F250 4x4 Jfollender 1961 - 1966 F-100 & Larger F-Series Trucks 5 02-07-2007 11:38 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
