broken lug nut stud - Ford Truck Enthusiasts Forums
broken lug nut stud
Old 07-25-2014, 01:38 PM
tlsjclark tlsjclark is offline
tlsjclark is starting off with a positive reputation.
broken lug nut stud
Can anyone give me a hint how to remove the lug nut stud plate on a rear wheel of an '04 Explorer? I removed the axle nut but don't see how I can get it off without damaging the e brake.
Old 07-25-2014, 09:22 PM
steve(ill)'s Avatar
steve(ill) steve(ill) is offline
steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.
The plate has a bearing inside and is mounted to the suspension arm and axle shaft. You cant get the plate off by itself. You have to remove the upper and lower ball joints and pull the knuckle and hub/ bearing unit all together.. It then takes a 20 ton press to push the parts apart.
Old 07-25-2014, 09:29 PM
steve(ill)'s Avatar
this photo will give you a basic idea of construction. The vertical cast arm is called the knuckle. The bearing is pressed into this, and the hub (5 stud plate) is pressed into the bearing.. Snap rings hold everything in place. It does NOT come apart on the truck.
Old 07-26-2014, 10:52 AM
shorod's Avatar
shorod shorod is online now
shorod has a very good reputation on FTE.shorod has a very good reputation on FTE.shorod has a very good reputation on FTE.shorod has a very good reputation on FTE.
There is supposed to be a wheel stud access plug in the dust shield. You can use a punch to remove the plug. Then you will have an access hole large enough to fit the stud through. The hole is located behind the parking brake shoe adjuster and appears to be the same hole that would be used to adjust the parking brake. You need to remove the rotor, then remove the parking brake adjuster and bottom spring before punching out the cover. The manual suggests the plug can be reinstalled.
If you want a PDF of the procedure from the factory service manual that shows images, send me a Private Message with the specific request.
-Rod
lug Nut + Drum removal on the '49 F6 fordtreexr 1948 - 1956 F1, F100 & Larger F-Series Trucks 20 09-07-2016 05:42 PM
Lug Nuts and Studs!!!!!!!! bignewf 1973 - 1979 F-100 & Larger F-Series Trucks 4 04-21-2016 05:24 PM
F250 Lug Nuts and STUDS.!!!!!!!!! bignewf 1987 - 1996 F150 & Larger F-Series Trucks 5 04-21-2016 12:31 PM
Saltwater = Frozen Lug Nuts djed 1999 - 2003 7.3L Power Stroke Diesel 51 06-12-2015 03:29 PM
Lug nut options for the OCD types? skyfox10 1987 - 1996 F150 & Larger F-Series Trucks 17 10-24-2013 04:00 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
