f250 gooseneck hitch same as f150
okay, so here is the deal. i need to hual my pulling tractor and trailer to the local pulls (no farther than 50 miles) as the truck i had been using is now needed for other things. the only problem is the only trailer wide enough to haul it with is a gooseneck, and i only have an f150. however, the trailer and tractor are not that heavy, the trailer is a double axle trailer with i think 5200 pound axles and is only 18 ft with a 4ft beavertail. the weight of the trailer is a shade over 1500 pounds. the tractor will be 4800 pounds at the heaviest with about 200 pounds of different weights that will be hauled with it, that puts me at a little over 6000 pounds total at the heaviest, and most of the time it will weigh less than that. i am wondering if a gooseneck hitch off an f250 of similar style will fit the f150 frame or if they are wider, i know the frames are thicker but that is it. before you all jump at me about it being a gooseneck, the load will only be a smidge over fords factory rated max trailer weight, and the truck will have a trans cooler and brake controller. so my question is will the f250 hitch work on the f150 or do i need to buy one specifically for an f150 (they are more expensive)? thanks
Received 3,107 Likes
on
Depends on the year, engine, trans and axles. I just stopped to look at a '77 F150 and when I looked in the bed, I was surprised to see a ball sticking up through the floor! As the gooseneck setup is easier on the truck overall compared to a conventional hitch, I wouldn't think 6k (if that is the actual weight) would be a big deal, again depending on what F150 you'll be using. I have had a much bigger load than that behind more than one F150.
on
kind of forgot about this thread so i never updated the situation. going to do a trade, and for my part of the deal i am getting a ford l7000 dump truck with a bad set of injectors, so my plan is to fab up some ramps that will slide back when i tip the bed back and hual my tractor and wood with it and get the best of both worlds
djm1204
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
07-20-2014 11:49 PM
Tore
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
09-22-2006 05:18 PM
Jesse_Bolt
05-12-2005 11:26 PM
flsct
11-25-2004 06:04 AM
