Check Engine Light - Ford Truck Enthusiasts Forums
Check Engine Light
Old 07-25-2014, 11:48 AM
matts156's Avatar
matts156 matts156 is offline
matts156 is starting off with a positive reputation.
Check Engine Light
Hi guys. When you first turn on your ignition, does your check engine light come on and if so, for how long? I have some poor running conditions that I'm sure would ordinarily light the CE light. My light flashes for a millisecond. Most cars and trucks I've driven over the years have the light come on for at least one or two seconds. Thanks.
Old 07-25-2014, 11:56 AM
David7.3's Avatar
David7.3 David7.3 is offline
David7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to behold
Yea I have a late 99 and my CE light comes on for a split second, than comes back on for 2 seconds. I tried it 3 times while I was typing this post. Get a quick flash than right back on for a couple seconds.
Old 07-25-2014, 12:00 PM
madpogue madpogue is online now
madpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to behold
^^^^^ That's normal. It's actually about 1/8 second. Blink and you'll miss it.....
And the vast majority of running issues will not turn on the CE light. Obviously anything fuel-related. Even those things that might set a code will not necessarily set the light.
Old 07-25-2014, 12:12 PM
73fan's Avatar
73fan 73fan is offline
73fan has a good reputation on FTE.73fan has a good reputation on FTE.
I'd recommend getting one of those ELM 327 Bluetooth OBD adapters off eBay and downloading TORQUE Pro for your Android. Very helpful for reading trouble codes as well as some live data. Inexpensive too. $25 for adapter and $5 for the app.
Sent from Nexus 4. IB AutoGroup
Old 07-25-2014, 03:16 PM
glovemeister glovemeister is offline
glovemeister is gaining momentum as a positive member of FTE.glovemeister is gaining momentum as a positive member of FTE.
So when the key to first turned to run, the DTC light will flash as a self check?
Water in fuel/check engine light Chris Carter 6.0L Power Stroke Diesel 2 10-04-2016 08:25 PM
pleASE HELP.check engine light kills trk. rbeesley Performance & General Engine Building 2 10-29-2015 04:56 PM
Check engine light hercyjerky 1999 - 2003 7.3L Power Stroke Diesel 3 10-07-2015 06:20 PM
Dashboard lights will not work! kayakfl1982 1999 - 2003 7.3L Power Stroke Diesel 4 04-24-2015 09:38 AM
check engine light finlander 2004 - 2008 F150 1 10-17-2014 09:16 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
