2wd or 4wd lift kit? - Ford Truck Enthusiasts Forums
Old 07-25-2014, 03:07 AM
jason832 jason832 is offline
jason832 is starting off with a positive reputation.
I recently converted my 85 f150's 2wd tranny to a np435/bw1345 combo. It's all working well so far and it's time for me to convert the front axle to a 4wd axle to complete the swap and finally drive a 4wd truck.
I have an axle coming from a realtive's junkyard for 200$ ready to bolt in, but since I want to lift the truck I figure I'll do it while I'm installing my new axle. The rear leaf springs are a set of 2wd, 2.5" leafs that will be staying that way. I can't remember if they have 5 or 6 leafs on each side, I just changed them not that long ago, so theres no need to add a leaf as far as I can see because the back sits a little high already. So I'm not sure which kit to get. Here are the two options i"m thinking of.
4WD Lift kit:
6in Suspension Lift Kit for 80-96 Ford 4wd F-150 Pickup / Bronco [470.20] | Rough Country Suspension Systems
Everything should work, except for the U-bolts and maybe the blocks? If so that would mean I would throw those away, and have to buy the correct ones for a 2wd setup.
2WD Lift Kit:
6in Suspension Lift Kit w/N2.0 Shocks for 80-96 Ford 2wd F-150 Pickup [472.20] | Rough Country Suspension Systems
The correct U-bolts and blocks are included for my 2wd leafs (says common sense ). However I'm not sure if any other parts will not be comatible with the new IFS or TTb (whatever you want to call it) front end.
What would my better option be? Buy the 4wd kit and need new U-bolts, or are the 2wd lift kits the same, just the right u-bolts for my truck.
Old 07-25-2014, 06:54 AM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
Buy the 4wd kit, and use the u-bolts and blocks in the back. I can't believe the rear sits 6 inches higher than the front right now. Are you saying the truck is standing on it's nose?
If you are running stock springs, the truck should have a slight rake with the rear being higher, that's the way the rear springs are designed. It will level out with a load on it.
If you want the "level" look that seems so popular now, I would still use the new u-bolts, and take a leaf out of the rear spring, cut the blocks a little bit if possible, or make new custom blocks.
6 inches is awful high, I hope you do not need driveshaft work on the front.
Old 07-25-2014, 08:33 AM
CountryBumkin's Avatar
CountryBumkin CountryBumkin is offline
CountryBumkin has a good reputation on FTE.CountryBumkin has a good reputation on FTE.CountryBumkin has a good reputation on FTE.
You will need to lengthen the front drive shaft for a 6" lift (maybe the back too). You will also want to get extended (longer) brake lines for the front.
Old 07-25-2014, 09:44 AM
Rogue_Wulff's Avatar
Rogue_Wulff Rogue_Wulff is offline
Rogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to behold
To correctly convert from 2wd to 4wd, you are already adding 2" of lift. The springs/shocks are the same up front, but there's a 2" difference in the height of the lower spring seat. This is why you have to add 2" blocks on the rear, so it matches the front.
6" lift is very hard on the axle pivot mounts up front. I know they include new pivot mounts, but they still aren't braced well enough for the stresses that can be placed on them.
In my opinion, if you want to go that high, you'd be better off going to the solid front axle swap right off the bat.
Old 07-25-2014, 10:05 AM
Right now the back end isn't 6 inches higher. It's maybe 3 or so just because there's already more leafs. So I would still probably want to add a small bit of lift in the back to go with a 6 inch front setup, meaning probably new U-bolts.
I kinda see what your saying about the solid axle swap, but I'm a little tight on cash, seeing as Im' going into collage, so I don't have the money to buy many tools, or have somebody fabricate etc. I have access to several good condition IFS setups, but I don't think there's any solid axles to pick from. It just seems like a big expensive unknown mission to swap it to me, and i would rather maybe just get a smaller lift if it came down to it.
Is a 6 inch lift likely to break anything? If so would a 4 inch be a little smarter? I don't plan on any real rock crawling or anything, just maybe a little water, mud that kinda thing that isn't going to scrape or bottom it out. Also if I go with a 6 or 4 inch lift, what is the largest recommended tire size? I think I've seen before that about 35 inches is as much as I'll want to push an 8.8. Any opinions?
Old 07-25-2014, 12:02 PM
Franklin2's Avatar
4 inch would be smarter. My f250 has a 4 inch with 35inch tires and they do not rub and have plenty of room.
Old 07-25-2014, 02:20 PM
I agree with Dave. Do the 4" kit.
If you decide to go to bigger tires later you can always add a body lift (plus you'll need more gearing for anything bigger than 35" tires).
My first tire change was from the stock 29" tires to 33" tires. That was a noticeable performance drop with the stock 3.54 gearing. It was livable though. I don't think going from 29 to 35" inch tires with stock gearing would be livable.
So, my point/advice is that a 4" lift is fine for 35 inch tires and you don't want to go any bigger (tire wise) unless you do a gear swap too.
Rough Country 4" lift for F250 85Supclub Ford Truck Parts for Sale 0 04-03-2015 06:14 PM
Opinions on level kit for 2013 SCab. TheBestNeverRest 2009 - 2014 F150 9 03-15-2015 09:13 AM
Suspension lift questions rollingthunder77 1973 - 1979 F-100 & Larger F-Series Trucks 19 02-17-2015 08:24 AM
SAS, Lift and Towing dillemma iverger 1994.5 - 1997 7.3L Power Stroke Diesel 7 02-07-2015 05:05 PM
Help deciding on a lift kit nelms Excursion - King of SUVs 5 01-26-2014 06:42 PM
Tags
2wd 4wd, conversion, leaf, lift, suspension, swap
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
