how to remove heater assembly 1968 (no ac)
i need to replace a leaking heater core on my 1968. there is no ac.
i evidently lack mechanical skill to know how to do this on sight.
anyway i loosened the three small bolts in the firewall from the engine side.
then i tried to remove the heater assembly. however it is still stuck
on the RHS with a vent of some sort. how can i loosen that?
also should i disconnect the battery before proceeding further?
thanks...
thanks...
After that, I needed to rotate the top of the entire heater assembly 90 degrees towards the back of the truck in order to get access to the 6 5/16" screw bolts that hold the heater assembly back plate (btw these are my terms only, since unfortunately I do not know the official terms) onto the assembly and hide most of the heater core. In order to do that, I needed to loosen with a flat screwdriver two screws that attached two non-electrical heater control wires to the assembly first. After these 8 screws came off, some electrical wires remained, but at least for my franken-ford they were not a problem, and I was able to remove the heater assembly back plate. With the heater assembly back plate removed, the heater core and a spacer sponge holding the heater core in place could be removed without difficulty.
The reason this is happening is because my heater core sprang a leak at the radiator shop while the shop was pressure-testing the old (leaking) radiator for leaks. A leak developed in the heater core. The shop replaced the radiator, left the heater core hoses disconnected, and charged me for a new heater core. However, we did not know which size heater core was in the heater assembly. I was trying to save some money by doing the removal myself.
Now I have to reverse the operation and get the new heater core back into the heater assembly, the assembly back into the cab, and re-connect thee hoses. I am debating whether to change the hoses. The rubber is not hard enough to be cracked but it is probably not something ordinary folks would call flexible either. :-) hmm...
Wow, that did not seem to be the case with my truck. However, I had my emergency flasher toggle switch trivially clipped to the bottom of the dashboard beneath the glove compartment. I had restored the glove compartment with a new cardboard compartment box from LMC or somewhere, and then re-lining the cardboard with TAP plastics fiberglass, one of my first restorations. I did not like keeping the emergency flasher toggle switch in its original (?) location inside the glove compartment box, so I left it hanging outside and below.
johninraleigh
12-14-2009 10:05 AM
Andy_H
06-12-2007 12:18 AM
