CAUTION: Rock Auto Rag Joints - Ford Truck Enthusiasts Forums
Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1973 - 1979 F-100 & Larger F-Series Trucks
Log In
Old 07-24-2014, 10:03 PM
51fordf5's Avatar
51fordf5 51fordf5 is offline
51fordf5 is starting off with a positive reputation.
Cool CAUTION: Rock Auto Rag Joints
Let me first say that I am okay and the truck is okay.
I was turning into the parking lot at work this evening when I heard a pop/snap noise and no longer had control over which direction the wheels were going. I was able to get it into a parking space, popped the hood and found this :
Click the image to open in full size.
I went through my ENTIRE steering system a few months back... New gear box, PS pump, borgeson steering shaft, everything. Including the rag joint, which I got from Rock Auto. I can't remember the brand off the top of my head, but I remember thinking that it seemed like the bolts were pulling in a little too much when I was installing it. They weren't shouldered like the ones I took out. But, I just brushed that off and figured that the design had changed and maybe the material the rag joint was made out of was stronger now or something.
Anyway, long story short, I had another rag joint from a different steering shaft I had bought that was good so I put that on and got it home. Here's a couple more from when I got it off. I'm very glad this didn't happen to me going down the road.
__________________
1979 F150 Short Bed 4x4
6.9 IDI Diesel/T19
Never ending project
Old 07-24-2014, 10:10 PM
lindstromjd's Avatar
lindstromjd lindstromjd is offline
lindstromjd is starting off with a positive reputation.
Might I suggest a solid shaft coupler as a replacement? You'll feel every single bump in the road (literally) but you'll never have to worry about it coming apart again. There's two different styles; one that bolts on to the top of the column and one that welds on. The bottom is the same with the splines for the steering box. Just a thought.
__________________
FTE Arkansas chapter member
1994 F350 Crew cab dually
7.3 Powerstroke, ZF-5
Current mods: T500, Rosewood 160/30's, Hydro-boost, 120v IDM, 6637 intake
Mods in the works: Inter-cooler, 3" intake plenums, SD GTP38r, MarkFuga E-fuel
Old 07-24-2014, 11:06 PM
blackjack33's Avatar
blackjack33 blackjack33 is offline
blackjack33 is starting off with a positive reputation.
Yikes, that could have been really bad.
Good to hear that you're ok.
__________________
1979 Bronco Ranger XLT
400-C6-NP205
Edelbrock 2171/Holley 4160
Rancho 2", 35x12.50 Goodyear MTR-K's
Old 07-24-2014, 11:10 PM
HIO Silver's Avatar
HIO Silver HIO Silver is offline
HIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud of
Wow.... 'glad it was a low speed decoupling.
Ya might want to inform Rock Auto about that failure. If they give a darn they can look up what you ordered and maybe track any other reported failures.. However, their lawyers will come back and say it was installed incorrectly.
$0.02
Old 07-24-2014, 11:14 PM
co425's Avatar
co425 co425 is online now
co425 is a name known to allco425 is a name known to allco425 is a name known to allco425 is a name known to allco425 is a name known to allco425 is a name known to all
Damn!! +1 on a borgeson shaft or the like.
__________________
1974 F250 4X4
Cummins 12v, NV4500 , np205, Dana 60 Front, GM 14 bolt rear.
Cummins swap/truck upgrade thread
http://m.ford-trucks.com/forums/show....php?t=1181279
LIBERALISM IS PESTILENCE!!!
Old 07-24-2014, 11:16 PM
mikeo0o0o0's Avatar
mikeo0o0o0 mikeo0o0o0 is online now
mikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud of
$0.02
Agreed, that would be my 2˘ too.
In theory that's not supposed to happen. The joint has two pins that should engage the steering shaft hub in case of joint failure. I can see one of them in the pictures, but obviously something went drastically wrong.
Glad you're okay, it could have been a lot worse!
__________________
http://centralfloridapoliticsblog.wordpress.com/
The universe is made up of electrons, protons, neutrons and morons.
Old 07-24-2014, 11:41 PM
Quote:
Especially considering it WAS a lot worse for his dad a few months ago when something similar happened to the same truck at highway speeds.
__________________
Old 07-25-2014, 12:04 AM
51fordf5's Avatar
Quote:
Yeah that's a possible solution. I'd rather deal with the bumps then worry about rag joint failure, but I didn't think they really failed like this.
Thanks, I appreciate it.
$0.02
Me too, my dad or I will be talking to them tomorrow about it. I hope they don't offer a replacement, cause I sure as heck don't want one. I just wanted to put it on here so that anyone who has one or is looking at getting one can see.
I am POSITIVE it was installed properly, not even overtightened. The only failure was in the actual joint itself, everything else is fine. But of course the lawyers wouldn't agree.
Quote:
I've got a borgeson shaft already, the rag joint had to be purchased separately and I figured "a rag joint is a rag joint".
Yeah, I'm not even quite sure what happened yet either. One of the bolts was still holding it on, but the holes where the other bolt and one of the pins are supposed to go were both torn. Then I think the last pin worked it's way out when I turned the wheel. Thanks though!
Edit: After further thought, I think that the reason those pins didn't do their job is that they seem smaller than they should've been. So they were too small to grab on to where they were supposed to.
Oh yeah, I don't think I ever posted about that here... That was a good time. That was a different issue, the bolt that was being used in the coupler between the steering shaft and the end of the column was apparently a little too small, which eventually led to the steering shaft working it's way off the steering column. That's what prompted me to go over EVERYTHING in the steering system and the rest of the truck in general, because who knows what other "fixes" might have been done.
__________________
6.9 IDI Diesel/T19
Old 07-25-2014, 12:16 AM
brian1080's Avatar
brian1080 brian1080 is offline
brian1080 has a good reputation on FTE.brian1080 has a good reputation on FTE.
not to be the bad guy, but if you had issues before, maybe it's not the ragjoints fault. You say it pulled out before,, maybe it was too far the other way now and stretching the rag joint. That is a short section of shaft to have two different failures and not have something else going on. Does the truck have a body lift? Is the steering shaft bent? I would def check out everything else from the steering wheel to the box, something is amiss.
I see in your sig the truck has a 3" body lift, is this the same truck? My truck has a 2" body lift and I extended the steering shaft to match up. 3" would put the stock shaft at it's limit and put a Hell of an angle on the ragjoint.
__________________
78 F150 SuperCab 4x4, 460/4spd
dana 60's, 6" susp / 2" body lift, 36's
(rebuilding here)
Old 07-25-2014, 12:25 AM
51fordf5's Avatar
The rag joint wasn't under any excess stress. The truck does have a 3" body lift, but the shaft that was in it (and the new borgeson shaft that I put in it) both extend out about 4" total to accommodate body lifts. The angle is obviously more than stock, but it was nothing crazy. I'll take a picture of the angle tomorrow, but I really do think it's fine.
__________________
6.9 IDI Diesel/T19
Old 07-25-2014, 12:34 AM
51fordf5's Avatar
Double post, but what do you guys think of replacing the rag joint with a ujoint style coupling instead?
__________________
6.9 IDI Diesel/T19
Old 07-25-2014, 01:39 AM
co425's Avatar
Quote:
That's what I was referring to.
This is what I have it's spicer U joints from bench work steering.
__________________
1974 F250 4X4
Old 07-25-2014, 07:17 AM
Yup, that's what I was talking about, too.
__________________
Old 07-25-2014, 08:30 AM
51fordf5's Avatar
Oops, I thought you were meaning something else. I like the looks of that, if you don't mind sharing, about how much did it cost for just the ujoint coupler at the bottom? I was looking at borgeson couplers and they were all above $100
Thought you were talking about something else too
Anyway, I went and looked more closely at the angle that the rag joint is at this morning, and I really don't see why it would be an issue. What do you guys think?
The angle just doesn't look large enough (to me) to put enough additional stress on the rag joint to cause concern. But then again, I'm still learning and maybe it is.
Edit: Also note how much larger those pins are on this one.
__________________
6.9 IDI Diesel/T19
Old 07-25-2014, 09:02 AM
co425's Avatar
I am unsure what the shaft cost originally. I bought it as part of a steering swap kit. They do have a web site.
__________________
1974 F250 4X4
Similar Threads
1979 F150 4x4 6.9 Diesel Build (With Pictures) 51fordf5 1973 - 1979 F-100 & Larger F-Series Trucks 85 04-23-2015 10:05 PM
Rear sliding window end caps 51fordf5 1973 - 1979 F-100 & Larger F-Series Trucks 9 06-22-2014 06:32 PM
Rust proofed? 51fordf5 1973 - 1979 F-100 & Larger F-Series Trucks 10 06-07-2014 03:14 PM
Check your bearings! 51fordf5 1973 - 1979 F-100 & Larger F-Series Trucks 15 03-01-2014 07:13 AM
Opinions wanted: Trim or no trim 51fordf5 1973 - 1979 F-100 & Larger F-Series Trucks 19 01-05-2014 08:41 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
vbulletin Admin Backup
