Transmission not going into gear at all - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 07-24-2014, 11:02 PM
JakeMac JakeMac is offline
JakeMac is starting off with a positive reputation.
I put a 95 e4od 4x4 in a 97 7.3 f350 would there be any other reason that it wont shift at all other then that the pump is broke. It has 16 qt's of fluid in it so its not low. Mabey the connections, everything seems to be hooked up ok. If its the pump how much would it be to fix if i bring the tranny in?
Old 07-25-2014, 12:21 AM
madpogue madpogue is offline
madpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to behold
Have you confirmed that it's not the transfer case?
Old 07-25-2014, 12:26 AM
Quote:
its in 2 high if thats what you mean and it worked last time i used it.
Old 07-25-2014, 12:41 AM
Quote:
So did the transmission. Either one is equally likely to be at fault. Simple test - shift to Park and attempt to push the truck. If it rolls, t-case is no longer engaging. If the Park pin holds, should mean t-case is okay, and indeed your problem is the tranny.
Is the OD-Off light on or blinking?
Old 07-25-2014, 12:57 AM
The OD light works like it should, ill have to try this tommarow, so ur saying that the connections wont have anything to do with the tranny not working?
Old 07-25-2014, 01:07 AM
Sure, any bad connection from the PCM to the tranny will cause a shifting issue. Usu. a shifting issue that the PCM detects sets a code, however, and you'd expect to see the OD-OFF light blinking.
Old 07-25-2014, 10:38 AM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is online now
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
A working transmission will shift into gear in both forward and reverse with or without the electrical connections. You can leave all the plugs unplugged and the trans will still move the truck.
Is there a filter inside the pan? You can see if the pump is working by putting a pressure gauge in the test port on the driver's side of the trans, near the front, just above the pan. It has a black hex head pipe plug from the factory. The thread is 1/8" NPT.
Old 07-25-2014, 02:06 PM
Hah seen this before i took the rear cooler line off while the truck ran and nothing came out so its a pump problem.
Old 07-25-2014, 02:07 PM
The park pin holds so i asume its the tranny pump.
Old 07-25-2014, 03:13 PM
Yes, it's the pump. No flow = dead pump.
Fuel pump? bvillarreal186 2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6 4 10-24-2015 09:56 PM
351w water pump dixiestripes351 Engine Swaps 8 06-25-2014 07:54 PM
1986 F150 fuel pump pressure Gene Beckstead 1987 - 1996 F150 & Larger F-Series Trucks 3 06-01-2014 11:03 AM
fuel pump pressure 1986 f150 Gene Beckstead 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 06-01-2014 07:43 AM
Power steering pump pulley? blucollar4xford 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 8 04-23-2011 10:49 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
