Chasing my tail again!
Old 07-26-2014, 11:56 AM
White Mountain Goat's Avatar
White Mountain Goat
White Mountain Goat is offline
Originally Posted by ArdWrknTrk
All three caps are under $5 @ Radioshack.
As was mentioned these things have a lifespan.
If the board is already out why wouldn't you replace them???
PCM is over 25 years old.
Be sure to maintain polarity.
That's what were working toward. We've got to check our local Radio Shack for parts. My previous posting was more or less an update, not a continued cry for help.
Old 07-26-2014, 02:23 PM
morningwood's Avatar
morningwood
morningwood is offline
the module plugs into that. there's a stator and a reluctor ring.can you seen pictures of this
Old 07-26-2014, 02:58 PM
V-10 duty's Avatar
V-10 duty
V-10 duty is offline
May I suggest, the EEC relay powers the FP relay, here's the test for the EEC relay,
<table class="ADVV1-HotlineArchives-Whites" cellpadding="0" cellspacing="0"><tbody><tr><td class="ADVV1-HotlineArchives-LeftRuledRows">
</td> <td class="ADVV1-HotlineArchives-RuledRows"> 1. Go to the Electronic Engine Control (EEC) Relay. Check for battery voltage on the Black/Yellow (BK/YE) wire from the fuse link. Check for battery voltage on the White/Light Blue (W/LB) wire with the key on from the ignition switch. Check the Black (BK) wire for a good ground. If all OK, there should be battery voltage out of the relay on the Red (or possibly Blue fuse link) wire. If there is none, inspect the connections at the relay. If OK, replace the relay and retest.
2. To verify that the EEC relay is the only fault, jump the BK/YE wire to the Red (or Blue) wire. This should power the system up and the truck should start and run.
</td></tr></tbody></table>
Old 07-26-2014, 03:11 PM
V-10 duty's Avatar
V-10 duty
if pin #22 at EEC is shorted to ground pump will run all the time with key on tan/lt grn. if you disconnect EEC 60 pin and check tan/lt grn for resistance to ground .005 or less good if any continuity to ground check for short to grnd. on pin #22 FP relay control
Old 07-30-2014, 12:26 PM
White Mountain Goat
Update! Turned out to be just a loose connection going to the EEC relay, some more of the PO hacked up wiring. Redid the connection and she's purring again.
RadioControlGuy85
01-07-2016 06:08 PM
RangerSaint
1983 - 2012 Ranger & B-Series
02-17-2012 02:10 AM
galaxiedan
07-01-2010 08:44 PM
nelly781
1978 - 1996 Big Bronco
01-06-2007 08:16 AM
stangman63
03-02-2004 02:54 PM
Quick Reply: Chasing my tail again!
