trying to help lil brother out need info(tires) - Ford Truck Enthusiasts Forums
Old 07-24-2014, 08:32 PM
7636074460 7636074460 is offline
7636074460 is gaining momentum as a positive member of FTE.
hey everyone. lil bro of mine has a 74 thats cut but otherwise stock. he is wanting new tires. i found these are hard to research on finding generic specs.
is there someplace that shows specs such as bolt patterns, factory wheel offset etc?
with that info i can figure out plus sizing etc unless someone has a setup were looking for?
he is wanting some BFG AT KO's and of course wants the largest he can fit. the only info i can base anything from is how big the UNCUT bronco can do.
PIC REQUEST!! anyone have cooper AT3's or STMAXX's??? Wanna see how those would look!
otherwise what would it take to go with a 31 10.50 15? lift? offset wheels?
i was reading that the uncuts can handle a 30 950 15 ? im sure its the rear fenders that was the limiter, but this one is CUT so how much width can we handle here?
i mainly just need a place or chart that shows specs in a nutshell since I dont have a bronco near me to put hands on the situation myself.
Old 07-25-2014, 08:24 PM
69 broncosport's Avatar
69 broncosport 69 broncosport is offline
69 broncosport is starting off with a positive reputation.
With cut rear fenders it will clear a 31x10.50 tire and the bolt pattern is 5 on 5 1/2" as for off set I try to stay center of the rim 15 x7 wheel with 3 1/2" back space the 7" whelk can handle a 10.50 tire
Post Your After Market Wheel/Tire Specs Here ToasterVan Transit Connect 3 01-29-2017 08:24 AM
2017 F250 Platinum Wheel Specs flycastr 2017 Super Duty 0 10-16-2016 12:10 PM
Wheel and Tire Questions D & D Offroad & 4x4 2 02-08-2016 04:15 PM
All over the road 0351mike 1966 - 1977 Early Broncos 22 10-14-2015 09:33 PM
Thinking of buying 68 bronco Old Brown Truck 1966 - 1977 Early Broncos 3 06-09-2015 09:48 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
