Removing the inner liner on the front wheel well/fender to fix a dent - Ford Truck Enthusiasts Forums
Old 07-24-2014, 06:22 PM
texasJ texasJ is offline
texasJ is starting off with a positive reputation.
Anyone got some tips on how to remove the inner liner on the front wheel well? I have a dent on the fender that I want to access and punch out by removing the liner enough to reach in there. Thought I would check with y'all before tinkering with it.
Old 07-24-2014, 08:24 PM
danorules's Avatar
danorules danorules is offline
danorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputation
It's pretty straight forward,just remove the bolts holding the liner in place
Old 07-26-2014, 06:46 PM
Done
Thanks dano, I did it. It was five 7/32" bolts, two 11mm bolts, and one Christmas tree plug. Had to shimmy the liner around pretty good to access the dent on the wheel well. Just stuck my hand in there and pressed on the inside of the dent and it popped out. It turned out really well IMO.
Before:
After:
Will have a paintless dent repair guy touch it up for far less than what I started with.
inner fender grommets breezesboy 1973 - 1979 F-100 & Larger F-Series Trucks 5 12-02-2014 04:21 PM
Ruggedliner-inner wheel well liner danorules 2004 - 2008 F150 7 02-18-2013 12:34 PM
Super good experience with Bullet Liner bladez51 1987 - 1996 F150 & Larger F-Series Trucks 3 06-08-2011 07:26 PM
wheel well liners 79 F150 dsouth77 1973 - 1979 F-100 & Larger F-Series Trucks 1 04-13-2010 12:39 PM
I need tips for fender trimming. bigblue 1973 - 1979 F-100 & Larger F-Series Trucks 1 02-11-2002 03:53 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
