Engine replacement - Ford Truck Enthusiasts Forums
Engine replacement
Old 07-24-2014, 05:38 PM
Kregj Kregj is offline
Kregj is starting off with a positive reputation.
Engine replacement
I have a 96 single cab f-150 300cubic inch motor, inline6, and I'm wanting to do some mainline work on it. I was think about putting a crate 5.0 mustang engine in it and put a slap shifter in it. I was wonder what I would need to do with the rearend and what y'all's thoughts would be?
Old 07-25-2014, 01:31 PM
Puddy's Avatar
Puddy Puddy is offline
Puddy is a splendid one to beholdPuddy is a splendid one to beholdPuddy is a splendid one to beholdPuddy is a splendid one to beholdPuddy is a splendid one to beholdPuddy is a splendid one to beholdPuddy is a splendid one to beholdPuddy is a splendid one to behold
Your going to need a donor engine harness from a 5.0 equipped truck. And convert to MAF, OR go Carbed. Depending on if it's stick or auto, need a standalone transmission controller. Such as quickus1/baumann to use.
Also you will need the oil pickup tube and oil pan from the 5.0/5.8 truck.
Expect to spend about 6000
Source- My Orange one is a crate x306 from ford racing.
Engine Rebuild 90' XLT 1987 - 1996 F150 & Larger F-Series Trucks 3 01-07-2016 01:16 PM
engine work. greentruck72 1987 - 1996 F150 & Larger F-Series Trucks 8 04-04-2015 04:34 PM
Stacks on a gasser 1992f150Hunter 1987 - 1996 F150 & Larger F-Series Trucks 80 03-13-2015 10:46 PM
75 360 timing and tune up help Jtay561 1973 - 1979 F-100 & Larger F-Series Trucks 2 02-19-2015 03:40 PM
Changing out 5.4 engine for a 6.9 diesel engine gusroofer 1997 - 2003 F150 1 01-25-2015 05:00 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
