Cutting out - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Cutting out
Old 07-24-2014, 03:16 PM
Redcows Redcows is offline
Redcows is starting off with a positive reputation.
Cutting out
I have a 07 f250 fx4 with 111000 miles on it. When it is loaded either by having a trailer on it or by it having to lug from a stop to get moving to back up a hill or if I stop to put it in 4x4 then it cuts out. If u knock it in neutral and give it gas it is fine but it lugs down and sputters out at Rpms of 1300 or less some of the time. It is a5.4 liter any ideas on what I need to change. I have ran injector cleaner through it at different times since it was new and I only run 91 octane
Old 07-25-2014, 08:01 PM
CampSpringsJohn's Avatar
CampSpringsJohn CampSpringsJohn is offline
CampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputation
Welcome to FTE. I don't own a 5.4 truck, so I can't really comment on it. But I can give your thread a bump! Perhaps this thread should be moved to a different forum?
Old 07-25-2014, 09:02 PM
senix's Avatar
senix senix is online now
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
Any codes on the motor? Check engine light?
When was the last time a fuel filter was changed on it and have you check the fuel pressure on it?
Old 07-26-2014, 09:29 AM
No there is no check engine light on I'm not sure that I have ever changed the fuel filter with as many as I have it's hard to keep up. How would I go about checking the fuel pressure ?
Old 07-26-2014, 09:30 AM
Quote:
Um ok where should I move it to? Thanks a ton
Old 07-26-2014, 10:43 AM
Hotpocket's Avatar
Hotpocket Hotpocket is offline
Hotpocket has a good reputation on FTE.Hotpocket has a good reputation on FTE.Hotpocket has a good reputation on FTE.
This is the best place for 5.4 questions...I would start with checking fuel pressure as well. You can rent one from autozone
Old 07-26-2014, 01:18 PM
redford's Avatar
redford redford is offline
redford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputation
Does it idle OK?
Old 07-26-2014, 03:03 PM
Quote:
Originally Posted by redford View Post
Does it idle OK?
Yes it idels fine the only time it lugs is if it has to back up a little incline or is stopped n the mud or starting with a trailer on from idle to 12-1300 rpm it cuts out if i drop n neutral and gas it is fine but under a load until it gets to around 1500rpm it lugs and cuts out once it gets up n rpm it runs great like always plenty of power
17.5 6 lug wheels 63flareside Ford Truck Parts for Sale 3 11-20-2016 05:33 PM
Grinding while in gear and lugging Cassadie Jeffers 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 09-04-2016 09:55 PM
Which lug nuts? jeff gammon 2004 - 2008 F150 1 06-04-2015 08:59 PM
1999 F250 light duty how to; 7 lug converting to 8 lug Big Norm 1997 - 2003 F150 39 11-10-2014 12:43 AM
Need Help-93 E150 Bolt/Stud Mystery/emergency pfhjr369 1968-2013 Full Size Vans 8 02-20-2013 07:15 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
