Periodic "No throttle response" - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Old 07-24-2014, 01:14 PM
HighOctane's Avatar
HighOctane HighOctane is offline
PMS: an obsession
HighOctane has a very good reputation on FTE.HighOctane has a very good reputation on FTE.HighOctane has a very good reputation on FTE.HighOctane has a very good reputation on FTE.
Hey all, I have an 08 F-550 with the 6.4L and periodically the throttle seems to crap out and have no response at all. The truck still idles, but there is nothing when depressing the pedal. Turning it off seems to reset it, but it has started doing this in the last couple days only. I realize the throttle is probably a drive by wire system, so is there a module or something that commonly acts up to cause this? Thanks for any help or recommendations in advance.
Old 07-24-2014, 01:29 PM
slowmans's Avatar
slowmans slowmans is offline
slowmans has a good reputation on FTE.slowmans has a good reputation on FTE.
Quote:
I know the 6.0's had issues with the pedal going dead but I havent seen this to often with the 6.4, I believe the pedal is actually electronicly controlling the throttle..? You may need a new assembly.
Old 07-24-2014, 02:16 PM
BoKnowsDiesel BoKnowsDiesel is offline
Former Vendor
BoKnowsDiesel is gaining momentum as a positive member of FTE.
Do you have any stored codes? I would think a fault in that system would set some sort of code (like a P1586) but if it's intermittent it might not set the MIL
Old 07-27-2014, 11:17 AM
langballs's Avatar
langballs langballs is offline
langballs is starting off with a positive reputation.
I had a similar problem where my truck would only get a quarter throttle on the pedal. Would be enough throttle to get up to speed on highway but that was it. I have a Mini Maxx tuner so I could check my throttle percentage and it said the pedal was working. Plus my cruise wouldn't work and no codes. I checked my LPFP at home with the key on engine off and it was very noisy. Replaced pump and truck like new again. Just something to check.
Old 07-31-2014, 02:54 PM
HighOctane's Avatar
PMS: an obsession
Apparently, according to the stealership, the EGT sensor is bad, and putting my truck into limp mode. $480 cures the problem I hope.
Old 07-31-2014, 08:29 PM
slowmans's Avatar
Wow, you can buy that sensor pretty cheap and change it your self!
95 F150 4.9 unhappy FirecrackerKTM 1987 - 1996 F150 & Larger F-Series Trucks 5 02-23-2015 07:46 PM
08 6.4 that seemed to have lost power while driving milk123 6.4L Power Stroke Diesel 35 01-31-2015 02:59 PM
Towing improves with engine break in Big Vic 6.2L V8 1 07-27-2014 06:50 PM
"Check Electronic Throttle" after JUMP STARTING??? Iron782 1997-2006 Expedition & Navigator 3 08-08-2013 01:25 PM
No Throttle Response, Good or Bad kailor 1997-2006 Expedition & Navigator 2 05-29-2012 12:18 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
