Dana 44 seal leak question
My front diff axle seal(s) are leaking.
I have never been into a diff before so I thought I should ask before
I jump in.
In order to replace the axle seals, do I need to remove the gearing
to replace the seals? It looks like I don't, but it also looks like it might be easier if I did.
The repair looks simple enough besides ripping the front end apart for an 8 dollar part.
Any kits I should avoid or buy? Tips/tricks/pitfalls I should look out for?
I jump in.
Received 3,102 Likes
on
as David said, you will be safe as long as everything is unlocked.
but for piece of mind, i would pull the plug and put a quart of gear oil in the diff anyway.
and to answer your question on replacing the seals, i always remove the carrier. it just makes things easier, and you get the added benefit of being able to thoroughly inspect everything while it is apart. .
reamer
03-23-2016 03:33 PM
Jared Putz
17
11-10-2003 03:19 PM
