1997 f350 low boost until 2500 rpm - Ford Truck Enthusiasts Forums
Old 07-24-2014, 12:12 PM
gdool gdool is offline
gdool is starting off with a positive reputation.
I have a 1997 f350 that doesn't make much boost until about 2500 rpm. I have had it to a mechanic and the only thing he can find is low exhaust back pressure. I have cleaned the tube, the sensor, the opening to the manifold, and even connected the sensor to the tube going to the MAP sensor. I also have a 1997 f250 and have swapped all of the following with no changes: PCM, IDM, EBPS, MAP sensor, and TPS. I have changed the fuel filter and clean the FPR screen. Any help would be greatly appreciated.
Old 07-24-2014, 12:52 PM
David7.3's Avatar
David7.3 David7.3 is offline
David7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to behold
Hows the waste gate? Does it have one, umnlug it and see what happens. you did check the turbo, quick spin by hand? No banana's in the tail pipe?
Old 07-24-2014, 12:57 PM
No waste gate. EBPV is functioning correctly. Downpipe is new and cat is gone.
Old 07-24-2014, 01:00 PM
BoKnowsDiesel BoKnowsDiesel is offline
Former Vendor
BoKnowsDiesel is gaining momentum as a positive member of FTE.
I'm sure there are others with better answers, but our Stiction Eliminator will help with turbo performance. Not saying it will fix your issue, but it may help it out.
Old 07-24-2014, 01:10 PM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE MOOSE_MACHINE is offline
MOOSE_MACHINE has a good reputation on FTE.MOOSE_MACHINE has a good reputation on FTE.
How do you know it's low boost.
Old 07-24-2014, 01:18 PM
David7.3's Avatar
How's it run, no miss fires no restriction on the intake side, you can take the air tube off and watch the turbine spin correct? Intake leaks? you changed a bunch of parts but they have nothing to do with boost. Simple air in air out, put some wet rags in the tailpipe and listen for any leaks around the manifold, up pipes, turbo flange, do you have a boost gauge? I'm throwing alot out at ya but hopefully something will stick.
Old 07-24-2014, 02:14 PM
Truck runs fine. No missing just can't get out of its own way at low rpms. Seems like it does not downshift as much as the f250 either. This morning, I drove with the mechanic as the passenger. He read the scanner as we rode around. He said that boost peaked at 13 psi but was really low at low rpms. There were some leaks on the intake plenums but they were fixed.
Old 07-24-2014, 02:47 PM
madpogue madpogue is offline
madpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to behold
Any pre-turbo exhaust leaks (manifolds, up-pipes)?
Old 07-24-2014, 03:07 PM
Don't think so. Mechanic said soot would be visible. Any tricks on how to check for these? Going out to try the wet towels on the tailpipe. Engine noise makes it hard to hear much.
Old 07-24-2014, 03:12 PM
Any thoughts on why the exhaust back pressure reading is low? Doesn't that have something to do with fuel?
Old 07-24-2014, 03:30 PM
There is a hole in the exhaust where the driver's side manifold meets the up pipe. I'm guessing that would be the problem.
Old 07-24-2014, 03:51 PM
tjc transport's Avatar
tjc transport tjc transport is offline
i ain't rite
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
Quote:
that sounds like you just found your problem
EBP/MAP & turbo issues Shane Wyatt 6.4L Power Stroke Diesel 5 01-19-2017 10:42 PM
Low turbo boost (puzzled) soberdude94 6.0L Power Stroke Diesel 7 05-04-2016 09:56 PM
MAP Sensor Troubleshooting fastdak 1994.5 - 1997 7.3L Power Stroke Diesel 3 12-27-2015 05:04 PM
EBP and the black cloud, more than just a pressure feedback? WatsonR 6.0L Power Stroke Diesel 25 06-18-2015 09:33 AM
2000 7.3 low boost question patnode22 1999 to 2016 Super Duty 4 10-31-2014 05:49 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
