Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Welcome to Ford-Trucks Forums!
Welcome to Ford-Trucks.com.
You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the Ford-Trucks Forums community today!
  #1 (permalink)
Old 07-24-2014, 09:24 AM
FordNew-boot's Avatar
FordNew-boot FordNew-boot is offline
FordNew-boot is starting off with a positive reputation.
Brakes locking up
Hi all, I have a 1981 Ford F100 Custom 2WD. Straight 6. I've replaced my master cylinder recently, and now my brakes are starting to lock up. I bench bled my master cylinder before install, and I bled my lines with a cheap bleeder gun from Auto Zone in the recommended order, furthest from the mc, first etc.. I did notice that the brake fluid was just barely flowing while bleeding. The brakes work for a few miles, then they lock up. After about a day, they're fine again and the whole process starts over. What did I do wrong? Any advice would be greatly appreciated. Thanks for reading.
  #2 (permalink)
Old 07-24-2014, 09:51 AM
CountryBumkin CountryBumkin is offline
CountryBumkin has a good reputation on FTE.CountryBumkin has a good reputation on FTE.
Is it the front brakes or rear brakes locking? Both wheels or just one wheel?
Could be a sticking caliper or piston, also rear brakes out of adjustment can cause one wheel to lockup faster than the other during hard braking. Problems due to heat from braking is more common in front brakes where it causes piston to stick, then it cools down and works okay for a while. Also, sometimes dirt/debris in the brake system around the caliper piston will cause a problem such as when the pads are replaced as the pistons are pushed back in their bore where the dirt has accumulated. Perhaps you stirred up the debris in the brake system/lines and now its causing the piston to stick in the caliper.
More details please.
__________________
F250 4x4 XLT Lariat, 460cid, 9.5:1, TFS 290 heads, Crane hyd. roller cam, Weiand Stealth intake, Quick Fuel Technologies HR780VS carb, MSD 6AL ignition and distrib., Hedman headers, 150HP NOS system, 7" lift, 4.56 gearing, 16.5x12.5Rx37 tires.
  #3 (permalink)
Old 07-24-2014, 09:54 AM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud ofFranklin2 has much to be proud of
The spec below is very important. If the master is being pushed ever so slightly, it will cover up the compensation ports in the bottom of the master and cause the problem you describe.
The push rod should extend past the face of the booster as follows:
1976: 0.880-0.895 in.
1977-81: 0.931-0.946 in.
1982-86: 0.980-0.995 in.
__________________
Dave F
1989 F250 XLT Diesel
  #4 (permalink)
Old 07-24-2014, 02:58 PM
CountryBumkin: I think it's the both in the front, that's where the "funny" smells and sounds were coming from after a quick trip down the road a few miles to pickup dinner for the family. I did nothing else but replace the master cylinder so I didn't think rear brake adjustment would be an issue; could I be wrong in that assumption? Thanks for the advice.
  #5 (permalink)
Old 07-24-2014, 03:00 PM
Are you freaking kidding me?! Wow, did not know that, thanks for sharing.
  #6 (permalink)
Old 07-25-2014, 09:12 AM
Quote:
UPDATE: I went home and messed with truck and noticed that once again the front brakes were locking up after a short drive. When I got home and put Ol Blue in reverse, the idle was enough to move him backwards. In drive however the brakes were keeping him from moving until i gave em some gas. Anyone have any ideas?
  #7 (permalink)
Old 07-25-2014, 10:40 AM
I don't think the moving in reverse but not forward means anything. The gearing in your tranny may be lower in reverse than 1st providing a torque advantage in reverse.
Try this, drive a short distance (5 miles) then immediately jack up the front end. See if the front when spin freely. Try again when cool. Obviously they should be free whether hot or cold.
Also, note that if the rear brakes are not working properly (sticking, out of adjustment, stuck parking brake cable, or faulty proportioning valve) it could make the front brakes seem like they are malfunctioning because you have to apply more brake pedal effort to stop the truck.
I had a similar issue once, where after driving a while the front brakes would drag (actually smoking). It turned out the my calipers (pistons) were sticking. A new set of rebuilt brake calipers fixed the problem.
__________________
  #8 (permalink)
Old 07-25-2014, 10:54 AM
Franklin2's Avatar
Along the same theme as my 1st post in this thread, I have a little ranger pickup that I got for free, it had the same problem and had been passed from one person to another, lots of parts replaced, and still the brakes would lock up after it was driven a few miles.
It turned out to be the booster. The booster was rusted and sticking, if you put your foot under the pedal and pulled up on it, it would not do it. Lots of wd40 didn't fix it either, I had to buy a rebuilt booster.
But the cause and the affect were the same. The booster was not releasing totally, slightly pushing on the master, which covered the compensation ports, and when the fluid gets warm it expands and instead of being able to expand into the master cylinder, it starts applying the brakes. Just because that little hole in the bottom of the master is blocked off.
__________________
Dave F
  #9 (permalink)
Old 07-25-2014, 12:46 PM
bill06447 bill06447 is offline
bill06447 is gaining momentum as a positive member of FTE.
So, did you adjust the pushrod? Classic symptoms, do it NOW lol ~Bill
  #10 (permalink)
Old 07-25-2014, 12:53 PM
Thanks so much for the advice. I will give it a shot. I'm thinking of going ahead and replacing lines and calipers just to be on the safe side. I mean, it certainly wouldn't hurt and seems as though it's fairly reasonable cost wise to do in a weekend. As long as the parts are available.
  #11 (permalink)
Old 07-25-2014, 12:57 PM
I haven't though about that either. I will definitely look into that as a symptom as well. Thanks for the input.
  #12 (permalink)
Old 07-25-2014, 12:59 PM
Quote:
You know what, I didn't adjust it. I didn't have much light to work in when I got home last night that I was trying to see if only 1 tire or both were locked up. This is definitely going to have to be a Sunday morning project. Thanks for the reminder!
  #13 (permalink)
Old 07-25-2014, 05:46 PM
5280's Avatar
5280 5280 is online now
5280 is gaining momentum as a positive member of FTE.
Maybe your new master cylinder is bad? Have you tried reinstalling the old one to see if you have the same symptoms?
__________________
1985 F350 XL. Crew Cab. Dually. 460 MT. 4WD.
1998 Land Rover Discovery.
2000 Excursion. 7.3l PSD. Limited. 2WD.
2005 Turbo Subaru.........my daily.
  #14 (permalink)
Old 07-26-2014, 08:38 AM
Quote:
I thought about that as well but I core exchanged the old master cylinder so I no longer have it. I think I'm just going to have to get start from scratch tomorrow and do a few things at a time. What will probably happen is replacement of the whole brake system. I don't want to be driving my kids around and inadvertently put them in danger. Thanks for the idea, I appreciate it.
  #15 (permalink)
Old 07-26-2014, 08:43 AM
This post reminded me that I had the same problem as Dave describes, once too. The easy test is get your foot under the brake pedal and lift. If the pedal comes up and the brakes release you know you have a sticking booster. However, in my case, the pedal would stick after each brake application and not just when the brakes/fluid was hot.
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Similar Threads
Brake Problems 85 F150 85AustinTucker 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 7 03-07-2014 11:06 AM
brakes lockup when engine is started Mearle 1987 - 1996 F150 & Larger F-Series Trucks 13 01-24-2014 10:26 PM
86 F250 clutch issues eraser5 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 0 09-13-2013 02:56 PM
Brakes lock up after MC replacement fl-mitchells 1973 - 1979 F-100 & Larger F-Series Trucks 16 03-15-2013 01:43 PM
1977 f100 351m front brakes rub and then let up at random F100Lock 1973 - 1979 F-100 & Larger F-Series Trucks 2 10-02-2012 10:13 PM
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
Advertising - Terms of Use - Privacy Statement - Jobs
vbulletin Admin Backup
