Battery dead...AGAIN
To find a draw close doors and turn everything off, set your meter to amps. Put prob on one side of fuze and the other on the other side of fuze. Watch amperage if there is a draw amperage will be shown. Best to use a meter with 20 amp max. This will direct you to the fuze that is the circuit casing the draw. A word of warning don't open door or turn anything with meter hooked up. When fuze is located I use a head light old stile with two wire attached. Remove fuze and plug into fuze with spade connectors attached to wires from hight light. If head light lights start unplugging connectors on they circuit when light goes out you found the draw. Buy disconnecting batter and testing from battery and cable you can cause problems with components that may need re flash or relearn
I have a HitchCam and a cap with an interior light. Other than that its stock.
you can buy a circut tester at harbor freight for 15 bucks that will let you test each fuse circut one at a time....so basically with each circut off you will know if something is drawing a load.
if you want a guess...pull the fuse on the air conditioner...sometimes the air conditioner clutch draws power even when off....enough to kill your battery over night.
You don't have to when you hook a big head light to the circuit, you can see it a mile away. Light lite complete circuit, light out open circuit. You can also use this for shorted circuit, lot better then spending $ on fuzes when your trying to find a short that keeps blowing them. Remove the blown fuze, plug in the light. get the wiring diagram for the circuit. Start unplugging or look for wire shorted when light goes out you found it.
on
It would cause a higher amperage draw while you were placing large demands on the battery such as when you engage the starter, but I can't think of any way that it would contribute to a drain on the system while the vehicle is parked.
