No power - Ford Truck Enthusiasts Forums
No power
Old 07-24-2014, 09:40 AM
dstraw dstraw is offline
dstraw is starting off with a positive reputation.
No power
I removed my battery to charge it and now that I re-installed it I have no power? Nothing no lights, no noise, not even a spark when i connect the pos terminal?
Old 07-24-2014, 09:52 AM
mikeo0o0o0's Avatar
mikeo0o0o0 mikeo0o0o0 is online now
mikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud of
First, make sure all of the cable connections are clean and tight and the cables are in good shape, but it sounds like you blew a fusible link.
Depending on what year you have, there is at least one link.
Look at the battery side of the starter solenoid, you'll see several smaller wires connected to that terminal too. Look for a wire (wires) that has a little plastic "flag" on it. It will say "fusible link 16 ga". This, obviously, is the fusible link. Tug on the link, see if it stretches or feels soft. If yes, then it's bad and needs to be replaced. You can get replacements at the parts store.
DON'T use regular wire, that would be like bypassing a fuse.
If the link is blown, you need to investigate why it blew before repairing it.
Old 07-24-2014, 09:56 AM
fmc400's Avatar
fmc400 fmc400 is offline
MSEE
fmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud of
What's the rest of the story? Battery put in backwards? What are you leaving out?
Old 07-24-2014, 10:04 AM
hairba11's Avatar
hairba11 hairba11 is offline
hairba11 is starting off with a positive reputation.
check the voltage of the battery? with key on?
why did you have to remove it from the vehicle to charge it?
how old is the battery?
Old 07-24-2014, 11:35 AM
So I have this wire from the pos post of the starter solenoid to a wiring harness (attached with a residential lug nut) is this the link?
Old 07-24-2014, 11:46 AM
fmc400's Avatar
MSEE
I can't tell. Some fusible links often say "fusible link." That doesn't look like a broken wire. Test it for continuity. Note that you didn't really answer any of our questions.
Old 07-24-2014, 11:52 AM
I don't have anyway to check voltage.
I removed the battery because it was easier than running extension cords to where the truck is.
The battery says 4/11 on it, but my charger showed it was in the green and fully charged.
Old 07-24-2014, 11:57 AM
The arrow shows where the wire in question was connected.
Old 07-24-2014, 12:13 PM
mikeo0o0o0's Avatar
Quote:
It may have been at one time. If that is (was) the link, it looks like someone may have already done what I said not to do, replace a fusible link with a piece of wire .
What is the color of the wire that that piece was attached to? and also, what year is your truck?
It looks like someone has already done some "expert" repairs on your harness . That seems to be a common problem on these old trucks .
This is what the fusible link should look like.
Old 07-24-2014, 12:15 PM
It's a 1974 F-100.
The wire that is was connected to is yellow (see pic above).
Old 07-24-2014, 12:20 PM
fmc400's Avatar
MSEE
You can't solve electrical problems without the proper tools, which in this case is a multimeter. Period. This thread is at a standstill until then.
Although, that's a bit of a moot point since the setup has been changed and some wiring removed.
Old 07-24-2014, 12:30 PM
fmc400 what multimeter do you recommend? Will a $20 unit work for troubleshooting the truck?
Amazon Amazon
Old 07-24-2014, 12:38 PM
mikeo0o0o0's Avatar
fmc400 is right, you DO need a multimeter to trouble shoot these problems.
I would say, to get by, yes a "cheap" meter will work. I prefer high quality tools but when you only use it once or twice it's hard to justify the expense.
I don't know how good you are at reading wiring diagrams, but here's a link to the factory schematics for the '74.
http://www.fordification.net/tech/wiring.htm
Also, the yellow wire shows to be power to the horn relay, so that wouldn't be your problem.
One last thing, I see you're new, welcome to FTE. You'll soon learn that when it comes to electrical problems, you've got the best guy on your side.
fmc400 is the "go to" guy for troubleshooting electrical gremlins that like to inhabit our trucks.
Listen and learn.
Old 07-24-2014, 02:47 PM
fmc400's Avatar
MSEE
For basic troubleshooting, any "cheapie" from most parts stores or tool shops will get the job done. I've seen analog meters as low as $10 that will work just fine. The main thing to look for when buying a multimeter for automotive work is quality, especially of the leads.
Old 07-24-2014, 08:37 PM
12.6 volts at the battery.
The piece of wire replacing my fusible link passed a continuity test.
I am suspecting my starter solenoid. How do I test it with a mutimeter?
New Power windows Cg willie Willie 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 10 01-20-2016 03:54 PM
FICM 6.slow power 6.0L Power Stroke Diesel 3 04-06-2015 02:41 PM
429 J no power 91-F700 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 7 06-30-2014 05:41 PM
No power to auxiliary power ports Dmoe512 6.7L Power Stroke Diesel 8 06-29-2014 11:23 AM
2000 power window schematic needed MONAVIERONJON 1999 - 2003 7.3L Power Stroke Diesel 3 06-14-2014 01:23 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
