AE & 4.2 - Ford Truck Enthusiasts Forums
Australia Chapter Join Chapter , Leader: ChunderDownUnder
AE & 4.2
Old 07-24-2014, 03:27 AM
Diesel Submariner's Avatar
Diesel Submariner Diesel Submariner is offline
Diesel Submariner is gaining momentum as a positive member of FTE.
AE & 4.2
G'day Fellas,
One of the mates has got an F250XL with the MWM Sprint 4.2L donk in it.
I'm thinking of hookin' up the AE to the OBD connection and check it out for him.
Has anybody used an AE on this arrangement?
Cheers,
Reg
Old 07-24-2014, 07:06 AM
SSSimon SSSimon is offline
SSSimon has a great reputation on FTE.SSSimon has a great reputation on FTE.SSSimon has a great reputation on FTE.SSSimon has a great reputation on FTE.
Probably someone in South America. You might be the first one in Australia Reg!
Old 07-24-2014, 12:40 PM
BigF350 BigF350 is offline
BigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputation
The thing with the 4.2, is it doesn't have many sensors. Engine is completely mechanical, the only real electronics are the dash cluster, the rear abs and interior A/C. I can't even remember what PIDS were available thru OBDII, but would be curious what you find.
Some of the Brazilians really wind up the Injection Pumps on them however:
Old 07-25-2014, 04:29 AM
AE & 4.2
G'day Fellas,
Well I'm aware of the basic design of the 4.2L 6.07 MWM Sprint and it's lack of sensors.
However they are OBD port fitted.
So I was really wanting to see what would show up in way of Diagnostics.
Anyway I hooked it up today and had no luck getting the AE to shake hands with it.
The lights lit up on the AE OBD connecter indicating it was alive.
I tried as many different configurations as I could but to no avail.
I have the Ford Enhanced Bundle so I guess this donk didn't get bundled up in Ford.
I know they where used in earlier Silverados, but I'm sure they were planted into some Ford Transits so expected it to come up??
The mates issue is he has no tacho indication. He has had the dash out and tested ok.
I've been trying to find the RPM sensor location but have had no joy
So if anyone can help with either knowing the sensor position or how to read the OBD port on these trucks, let me me know.
Cheers,
Reg
Old 07-25-2014, 11:00 AM
Yeah, IIRC, no diagnostics on them.
Is the rpm sensor not on the injector pump?
Old 08-09-2014, 12:19 AM
Blue7.3's Avatar
Blue7.3 Blue7.3 is offline
Blue7.3 has a great reputation on FTE.Blue7.3 has a great reputation on FTE.Blue7.3 has a great reputation on FTE.Blue7.3 has a great reputation on FTE.Blue7.3 has a great reputation on FTE.
4.2 is not listed in the Ford Enhanced Bundle , AE works good on my 7.3
Old 08-09-2014, 04:29 AM
RPM SENSOR
G'day Fellas,
I did throw the AE over the mates 4.2 Ftruck.
It did not pick any codes as expected. They do have an OBD11 connection port and they do have limited codes that can be picked up with the correct scan tool.
Anyway we did track down the Engine RPM sensor (pick up) for the Tacho on these MWM fitted F250 XL.
I could not see any other connector or wire to the fuel pump area as was the suggested position of the RPM sensor. The only thing on the Bosch fuel pump that is electrical is the 'Fuel Shut Off Solenoid'.
Anyway more searching found a single wire hanging loose off the back of the 'Alternator'.
Plugged it onto the obvious pin (only one without a wire connected). Fired her up and bingo Tacho happily dancing around with the rev changes.
Pinched it tight to make sure it won't shake off under it's own and all is good.
So there ya go, the RPM sensor for the Tacho on these 4.2L 6.07 MWM Sprint F250s is fed off the Alternator.
Cheers,
Reg
Old 08-09-2014, 08:04 PM
Blue7.3's Avatar
If you have access to a unlocked Superchip 1705 they are good for pulling codes and that's about it.
Old 08-15-2014, 07:16 PM
Rusk Rusk is offline
Rusk is starting off with a positive reputation.
Just had my local dealer connect up to OBD to pull down DTC's because ESOF won't work properly. There are a whole bunch or codes in there for faults in body wiring, 4wd, instrument cluster, abs, air bag etc.
Re tacho probs- had something similar - tacho started to become a bit erratic - turned out to be worn brushes & sliprings in the alternator.
Old 08-15-2014, 07:37 PM
Blue7.3's Avatar
B codes are not to much of a problem, i had some problems with the ESOF system , turned out to be the PVH solenoid, I also used a brake vacuum gun to diagnose this.
CAR Auto Hand Power Brake Line Bleeder Bleeding Pressure Vacuum Pump Tool KIT | eBay
4.2 quits while driving YZ450F 1997 - 2003 F150 1 08-14-2016 10:20 AM
what r the differences between a 2001 4.2L and a 1998 4.2L aaron1969 1997 - 2003 F150 0 12-12-2014 07:21 PM
Test.... SStans Testing..... 0 06-30-2014 11:59 AM
AE is driving me to drink... nlemerise 1999 - 2003 7.3L Power Stroke Diesel 21 02-04-2013 11:38 PM
C6AE vs Performer 390 intakes DrainBramage FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 8 08-21-2011 09:06 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
