CEL after 10 mins of running....how to diagnose? - Ford Truck Enthusiasts Forums
Old 07-23-2014, 09:13 PM
SoCalAngler's Avatar
SoCalAngler SoCalAngler is offline
SoCalAngler is starting off with a positive reputation.
Hello--
My CEL comes started coming a few days ago. It comes on about 10 mins of driving. Once I shut her down and restart, CEL goes off. After I drive for 10 mins it comes back on.
Things I've done to engine right before this started to occur...
1. Changed plug wires, dist cap, rotor
2. Replaced air filter and PCV filter
3. Removed batt cables (pos and neg) to install chemical pads under terminals.
4. Changed oil and filter (synthetic 10W/30 - FL-1HP filter).
5. Initial drive to test run vehicle, (turned off OD to test OD functionality as I never turned it on/off since I purchased a few months ago)
During the initial drive, after all above was performed, is when this started.
What can this be? I do not have an OBD I to check codes
Thanks!
Old 07-23-2014, 09:18 PM
94GreenTruck 94GreenTruck is offline
94GreenTruck is starting off with a positive reputation.
I have this same problem, mine is due to an o2 sensor that i cant get unstuck... it comes on after a few minutes because certain sensors need to be warmed up. O2 sensors need to be warmed up as well as a few others
Old 07-23-2014, 09:29 PM
How can you be sure it is an 02 sensor? why not replace as opposed to trying to get unstuck? BTW...how do you get it unstuck?
Old 07-23-2014, 09:38 PM
I know its bad haha. Long story... lets just say water damaged. And by stuck i mean stuck in the bung on the exaust pipe. Pb blast, an acytelene torch and an 02 socket and still cant the dang thing outta there to replace it
Old 07-23-2014, 09:40 PM
Benztechnc's Avatar
Benztechnc Benztechnc is offline
Benztechnc has a very good reputation on FTE.Benztechnc has a very good reputation on FTE.Benztechnc has a very good reputation on FTE.
I believe you can jump a couple of pins and be able to pull the codes, or purchase a code reader. iirc mine wasn't expensive.
However I would check over everything you touched, leaned on or took off. It could be as simple as a vacuum hose getting knocked off.
Old 07-23-2014, 10:02 PM
I checked all hoses and all around engine but did not see anything out of place
Old 07-24-2014, 07:33 AM
rla2005's Avatar
rla2005 rla2005 is offline
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
Quit guessing what is triggering the CEL.....
Warm up the engine then do this: How to run a Self Test
List the codes, by number and when they were displayed, here. We can help you decode them.
Most likely you should get three digit codes. 3 Digit Code Definitions
Old 07-24-2014, 07:47 AM
cliff_mennenger's Avatar
cliff_mennenger cliff_mennenger is offline
cliff_mennenger is starting off with a positive reputation.
You have to run the self test to retrieve DTC info. No reason to load the parts shotgun more than once.....
Old 07-24-2014, 06:11 PM
SteelHorse4x4's Avatar
SteelHorse4x4 SteelHorse4x4 is offline
SteelHorse4x4 is starting off with a positive reputation.
Quote:
LMAO. never heard that one before but so true.
Old 07-24-2014, 06:15 PM
I want to laugh too....what does this mean?
Old 07-24-2014, 06:55 PM
wag53's Avatar
wag53 wag53 is offline
wag53 is starting off with a positive reputation.
Quote:
You're kidding, right?
Old 07-24-2014, 08:57 PM
This is the name for the all too common approach to repair work that involves the replacement of parts with out any real thought or diagnostic process....in the case of a "shop" it is often the most profitable route...ranks right up there with the "wallet flushing" and "pad slappers"....So instead of spending the effort to make the repair "you" hypothetical of course....just "load" the shotgun with a few parts and pull the trigger! You might get lucky and actually "fix" it.
Most times DIY folks just don't have the info (service info, wiring diagrams, code setting criteria etc.) tools or knowledge to really dig in and make the repair themselves. That's where forums like this come into play...lots of priceless info here for anyone that can find it.
Take care.
Old 07-24-2014, 09:57 PM
Quote:
They can be a real fight! Sometimes to get it done I just cut the harness at the O2 sensor and drop the pipes. Hit the offender with an impact and see what happens next. Most don't break off.....they give up before that. Running with a stuck O2 isn't good for the long term health of the engine. Hard on cats or pistons.
Old 07-25-2014, 08:46 AM
Take care.
Thanks! That's what I thought, but I wanted to be sure. I'm not the shot gun type and prefer to diagnose correctly.
Old 07-25-2014, 08:50 AM
You are in the minority.
Take care.
2001 E-350 7.3 SD Cranks, idles good, runs 1/2 power, then at 45mph major turbo boost and runs BAD! jonguy35 1999 - 2003 7.3L Power Stroke Diesel 7 11-26-2016 11:56 PM
Intermittent problem Skyhawk Greg 1994.5 - 1997 7.3L Power Stroke Diesel 73 09-15-2014 10:29 AM
03 Explorer P2196 & P0405 Code Question wiwillis1980 Explorer, Sport Trac, Mountaineer & Aviator 1 06-22-2014 05:22 PM
Throwing codes upon cold start only. cw_mi Excursion - King of SUVs 0 05-27-2014 09:27 AM
95 f150 code 332 fordka 1987 - 1996 F150 & Larger F-Series Trucks 5 07-01-2013 10:53 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
