Service engine light being tripped by EGT? - Ford Truck Enthusiasts Forums
Old 07-23-2014, 08:15 PM
351Cleveland C4's Avatar
351Cleveland C4 351Cleveland C4 is online now
351Cleveland C4 has a great reputation on FTE.351Cleveland C4 has a great reputation on FTE.351Cleveland C4 has a great reputation on FTE.351Cleveland C4 has a great reputation on FTE.
Hey fellas, I got a question that hopefully someone will have the answer to.
What temperature does EGT have to reach before the service engine soon light comes on?
When were driving in the mountains, climbing at high power/ high boost conditions will trip the light after a few seconds. It goes back off after we top the hill and let off. So I figure it must be an EGT triggered situation.
The truck is E99, tuned with a DiabloSport predator tuner. Stock turbo, injectors.
We've been running it this way for years and never has anything blown up or melted. A couple times we've even had the turbo start glowing cherry red when were towing really hard.
Old 07-23-2014, 08:41 PM
F350-6's Avatar
F350-6 F350-6 is offline
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
You can melt your engine block into a puddle before the SES light will come on for EGT. There's no EGT sensor in the truck from the factory so there's nothing for the computer to read and cause it to trip a light.
Usually it's a P1211 that sets the light in those conditions, which is common for a chipped or tuned truck. The light goes off after a few minutes, no harm, no foul.
You can look at upgrading the HPOP if it really bothers you, but I'd recommend at least pulling the code first.
Old 07-23-2014, 08:50 PM
greg_8507 greg_8507 is offline
greg_8507 is starting off with a positive reputation.
Quote:
A pyrometer might be a good investment.
Old 07-23-2014, 09:18 PM
Ok cool. I knew it wasn't really something to worry about cuz it still runs great after all these years.
As far as a pyrometer, ehh... if we had one we probably wouldn't push as hard. Haha
Old 07-24-2014, 07:25 AM
dsquared's Avatar
dsquared dsquared is offline
dsquared is a splendid one to beholddsquared is a splendid one to beholddsquared is a splendid one to beholddsquared is a splendid one to beholddsquared is a splendid one to beholddsquared is a splendid one to behold
You should be able to pull DTC's with the Predator; I don't remember if it shows stored codes, but I,ve seen the P1211 when I would get heavy-footed......and the Predator will also clear DTC's
Old 07-24-2014, 07:39 AM
F-250 Super Duty's Avatar
F-250 Super Duty F-250 Super Duty is offline
All Around Good Guy
F-250 Super Duty has a very good reputation on FTE.F-250 Super Duty has a very good reputation on FTE.F-250 Super Duty has a very good reputation on FTE.F-250 Super Duty has a very good reputation on FTE.
My bet is you are getting the "ICP is lower/high than desired" code. I got that one a few times when dragging the camper over the mountains.
Old 07-24-2014, 11:28 AM
white Buffalo's Avatar
white Buffalo white Buffalo is offline
white Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud of
Yep, just like the 2 previous posts said...P1211 code most likely tripping the SES light. HPOP not being able to keep up with the Demand from the program. I had the predator before and you can pull & clear codes like said above. I remember EGT's being fine in the tow programs but she will get very hot (+1250 EGT's) in the higher HP tunes .
Old 07-24-2014, 11:42 AM
Deluxe06's Avatar
Deluxe06 Deluxe06 is offline
4000 rounds a min
Deluxe06 is a splendid one to beholdDeluxe06 is a splendid one to beholdDeluxe06 is a splendid one to beholdDeluxe06 is a splendid one to beholdDeluxe06 is a splendid one to beholdDeluxe06 is a splendid one to beholdDeluxe06 is a splendid one to behold
Over boost will also set an ses light that will go out a minute after it's set. Don't remember what code it is though.
Old 07-24-2014, 11:51 AM
Were just running the 65hp econo tune. Boost will peak out around 24 IIRC.
Will there be a code stored even though the light isn't staying on?
Old 07-24-2014, 12:07 PM
dsquared's Avatar
I believe there is, but I no longer have my Predator. IIRC, it will show stored codes and tell you it is "Not Ready"...all that means is you need to drive it before it erases the code from memory....this info, and 4%.00, will get you a cup of coffee @ Starbucks!!
Old 07-24-2014, 01:13 PM
DP-Tuner's Avatar
DP-Tuner DP-Tuner is offline
PREMIUM SPONSOR
DP-Tuner is a splendid one to beholdDP-Tuner is a splendid one to beholdDP-Tuner is a splendid one to beholdDP-Tuner is a splendid one to beholdDP-Tuner is a splendid one to beholdDP-Tuner is a splendid one to beholdDP-Tuner is a splendid one to behold
Just for future reference the PCM in the 7.3l years does not monitor EGT's. You have to add a Pyrometer gauge to see the EGT's. 24psi of boost sounds normal for a 60ish hp tune. You have the tools with the Predator to read DTC's. If the code is still stored in th PCM it will show it. Let us know what it is and we can help diagnose the possible issue.
~Diane
__________________
Jody & Diane Tipton- DP-Tuner®
FTE Legacy Sponsors since 2006
Custom tuning for 7.3l, 6.0l, 6.4l and 6.7l
Get Tuned! 828-221-0076 ext. 802
Become our Facebook Fan
Old 07-24-2014, 03:28 PM
Whitey Ford's Avatar
Whitey Ford Whitey Ford is offline
FTE-Spread The Knowledge
Whitey Ford has a great reputation on FTE.Whitey Ford has a great reputation on FTE.Whitey Ford has a great reputation on FTE.Whitey Ford has a great reputation on FTE.Whitey Ford has a great reputation on FTE.
Quote:
Like your A10 picture. Dr. Gatling would have been proud of it's GE Avenger 30mm Cannon! Do you remember seeing them in Desert Storm in the 90's firing on the Iraqi's leaving Kuwait on the Iraqi Highway? It took two years to clear all the vehicles they fired on.
10 tons of pure American Freedom!
Old 07-24-2014, 04:10 PM
I'm not too worried about it. I'd have to find the tuner to read the codes. And I don't remember where it's at haha. Thanks for the info guys.
Turbo Cool Down (Timer vs. EGT) ghott 6.0L Power Stroke Diesel 4 01-28-2016 04:39 AM
Low on Power High on EGT Traildust 1999 - 2003 7.3L Power Stroke Diesel 15 09-23-2015 04:49 PM
What makes high EGTs? Ezalycasaid 1994.5 - 1997 7.3L Power Stroke Diesel 26 07-21-2015 04:22 AM
'11 F350 Med unit with more problems golfmedik 6.7L Power Stroke Diesel 20 03-07-2014 09:11 AM
Pulled some weight this weekend Sunline Fan 6.4L Power Stroke Diesel 6 10-25-2011 04:01 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
