Rough Idle Temperture Related - Ford Truck Enthusiasts Forums
Old 07-23-2014, 07:04 PM
devbravo's Avatar
devbravo devbravo is offline
devbravo is starting off with a positive reputation.
1995 F250 w/351W.
no CEL, No OBD I codes (111 no errors KOEO & KOER)
Idle surges between 500 & 700 rpm.
When engine is cold and early in the Morning the idle surge is barely noticeable. However as engine heats up and the day gets warmer the
Idle surge is very noticeable.
Replaced EGR and TPS sensor, new IAC valve. new PCV
New plugs, MSD distributor cap and coil.
Replace all those brittle plastic vacuum lines w/color coded neoprene vacuum
lines. Engine has great acceleration.
However this idle surge is puzzling.
Any Thoughts and/or ideas would be greatly appreciated.
Thanks
Guy
Old 07-23-2014, 11:16 PM
Spktyr Spktyr is offline
Spktyr is gaining momentum as a positive member of FTE.Spktyr is gaining momentum as a positive member of FTE.
Coolant temperature sensor.
Old 07-24-2014, 04:57 AM
devbravo's Avatar
coolant temperature sensor?! Hmmm Thanks I'll look into that possibilty
Old 07-26-2014, 10:45 AM
devbravo's Avatar
Turns out I had a loose spark plug wire was not making a good connection
so the number 2 cylinder was running rough.
Old 07-26-2014, 12:52 PM
rla2005's Avatar
rla2005 rla2005 is offline
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
Thanks for the reply back with the root cause and resolution.
Intermittent Idle Surge and Surge/Miss at Low Throttle bigjd Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 6 01-18-2016 02:48 PM
95 5.8L occasional surging idle, esp. when cold FightinTxAg 1987 - 1996 F150 & Larger F-Series Trucks 19 04-24-2015 08:29 AM
New 351w running rich and bad idle '90-f150-302-5spd 1987 - 1996 F150 & Larger F-Series Trucks 17 03-25-2015 03:21 PM
Surging/hesitation/power loss at low RPM capriceragtop 1987 - 1996 F150 & Larger F-Series Trucks 2 07-27-2014 07:21 PM
94 f150 spark knock, rough idle timbramo Ford Inline Six, 200, 250, 4.9L / 300 17 11-12-2013 08:39 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
