Air whistle / leak from turbo? - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Old 07-23-2014, 05:33 PM
themaniam1 themaniam1 is offline
themaniam1 is starting off with a positive reputation.
Fairly new to Diesels and especially turbos but have enough mechanic knowledge to come close to a problem. So I have a 2008 F-450, engine was replaced just before I bought it with a factory crate engine. It has 13,000 on it and is still under the 3 yr engine warranty.
Problem: When the boost starts, it make a sound like an air compressor leak and gets louder until about 10 psi boost and then starts to whistle. The whistling just gets louder and higher pitched as the boost goes up. It sounds like a fire truck if is vary the throttle. If I let off the throttle and let the boost drop below 10 then the whistle stops. If I gently accelerate I can keep it from whistling but still get the air leak sound. Any ideas? Do I take it to a dealer?
Old 07-23-2014, 05:55 PM
sxrfun sxrfun is offline
sxrfun is gaining momentum as a positive member of FTE.sxrfun is gaining momentum as a positive member of FTE.
Check all your intercooler boots and clamps and make sure they are tight. Also check where the intake mounts on to the turbo and make sure all intake clamps are tight as well.
Old 07-23-2014, 06:05 PM
JWC 3's Avatar
JWC 3 JWC 3 is offline
JWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputation
Also check for missing, broken exaust manifold bolts . Just had a 550 with a high pitch whistle . It was a broken manifold bolt .
Old 07-23-2014, 09:03 PM
You guys are awesome. Found the leak. It was the lower down pipe boot right in the front of the truck where it connects to the bottom of the intercooler. Now I just have to find a parts store that has one or go to the dealer in the morning.
Thank you for your help.
Old 07-24-2014, 08:49 AM
When you put new boot on make sure to clean where it mounts on intercooler and hot side pipe with brake cleaner to make sure there's no oil residue. Also when you put it together...spray some hair spray on parts that go together...it'll act as glue and help keep it from popping off under higher boost numbers.
Old 07-24-2014, 09:30 AM
Will do. I am about to drive to the dealer to get the part. Thank you for timely advise.
Old 07-26-2014, 11:07 PM
Update. Installed new boot, $65 from the dealer, and it drives quite (normal sound) and has power again. Towed the boat to the lake and all is well.
No turbo at idle Andrews6.0 1999 to 2016 Super Duty 2 01-30-2014 08:52 AM
Whistle when letting up on accelerator JJKK 6.4L Power Stroke Diesel 11 09-17-2013 04:13 PM
No turbo whistle and exhaust SUPER loud after PCM replaced...? AndeyHall 6.0L Power Stroke Diesel 11 10-14-2010 06:43 PM
Strange Whistle, (possible intake leak) 81-F-150-Explorer Ford Inline Six, 200, 250, 4.9L / 300 8 06-10-2009 09:10 PM
Whistle/ Air leak Sound? joe blow 6.0L Power Stroke Diesel 19 04-07-2009 02:44 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
