Making a parts list. - Ford Truck Enthusiasts Forums
Old 07-23-2014, 04:05 PM
22fordguy 22fordguy is offline
22fordguy is gaining momentum as a positive member of FTE.22fordguy is gaining momentum as a positive member of FTE.
So I am attempting to put together a parts list for some upcoming work i want to do once I am back in Colorado. Main point of the work is to do the head studs but figure I might as well do a oil cooler, and all the updated stand pies dummy plugs and turbo tubes. I have the majority of my list made but I cant find a list of what gaskets and various other parts I will need to complete the job. If any one has a list of these that would be great also any input on what other work i should do or plan for. I already have a BPD egr cooler and my sinister coolant filter should be here tomorrow.
Old 07-23-2014, 04:13 PM
Shaneb75's Avatar
Shaneb75 Shaneb75 is offline
Strokin Okie
Shaneb75 has a great reputation on FTE.Shaneb75 has a great reputation on FTE.Shaneb75 has a great reputation on FTE.Shaneb75 has a great reputation on FTE.
Depending on mileage, you may consider new lifters while you are in there. You will also need rocker box gaskets. Valve cover gaskets are reusable, but may be brittle...
Old 07-23-2014, 04:29 PM
I am coming up on 170000 Miles. I knew the cover gaskets were reusable but as many times as I have had them off I think I will just replace them this time Didnt know about the rocker box though
Old 07-23-2014, 04:40 PM
Shaneb75's Avatar
Strokin Okie
I believe the intake gaskets are reusable as well, but I don't reuse them. As far as lifters are concerned, I bet the consensus will be to leave them alone at 170k. I don't think failures are considered common on the 6.0, but it happens.
New ones will be going in mine when it gets studded.
Old 07-23-2014, 05:23 PM
9228.bobcat's Avatar
9228.bobcat 9228.bobcat is offline
9228.bobcat has a great reputation on FTE.9228.bobcat has a great reputation on FTE.9228.bobcat has a great reputation on FTE.9228.bobcat has a great reputation on FTE.
Go with the 6.4 pushrods, 6.4 banjo bolts, exhaust gaskets and bolts, turbo reinstall kit, blue spring, dummy plugs, stc fitting, 4 copper washers for fuel lines.
Old 07-23-2014, 05:34 PM
6.4 bolts are on the list. blue spring is done. dummy plugs and stc are on the list as well. turbo kits I try to keep on hand. What is the advantage of the 6.4 push rods.
Old 07-23-2014, 05:42 PM
Shaneb75's Avatar
Strokin Okie
Quote:
Eric, didn't the 6.0 push rods get updated, basically the same as the 6.4 now 8C3Z-6565-B?
Old 07-23-2014, 05:46 PM
Sure did. They are the 6.4 pushrods. The benefit is that they are I think .020 shorter than the old pushrods. Helping the cam and lifters not to prematurely wear out.
Old 07-23-2014, 06:17 PM
diesel_dan's Avatar
diesel_dan diesel_dan is offline
diesel_dan is a splendid one to beholddiesel_dan is a splendid one to beholddiesel_dan is a splendid one to beholddiesel_dan is a splendid one to beholddiesel_dan is a splendid one to beholddiesel_dan is a splendid one to behold
Quote:
Do you mean the oil supply and drain tubes to the turbo? If so, your '07 should already have them...
Old 07-23-2014, 07:40 PM
Well then I guess those will be taken off the list.
Old 07-23-2014, 07:48 PM
diesel_dan's Avatar
Just more funds for other goodies
Old 07-23-2014, 07:54 PM
Would it be worth doing a HPOP or would I be ok reusing the one in it. Also I am not trying to make enourmous power from the truck but I have seen people upgrade the intercooler to one with metal ends. The cold side metal CAC is also on the list and depating a new turbine on the turbo.
Old 07-23-2014, 07:59 PM
diesel_dan's Avatar
The HPOPs on the later trucks are robust, but have you changed out the STC fitting off the HPOP? That should be on the list for sure...
Old 07-23-2014, 08:11 PM
Current list is:
ARP studs
OEM gasket
dummy plugs
Stand pipes
oil cooler
STC update
turbo rebuild with new wheel (possibly)
Intake gasket
exhaust gasket
rocker box and valve cover gasket
6.4 pushrods and banjo bolts
Injector o-ring set
Already installed:
BPD egr cooler
Sinister coolant filter (In the mail)
Scanguage II
Old 07-23-2014, 10:47 PM
Yahiko's Avatar
Yahiko Yahiko is online now
Yahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputation
You also need the two that go to the fuel filter housing banjo bolt.
Someone said lifters but to do that you need access to the rear
of the engine and have to take that cover off to pull the branch tube.
So to do that your going to need a HPOP gasket set and a rear main
seal and the silly tool to install it.
Sean
Aux Trans cooler troubleshooting oklahomie 1999 - 2003 7.3L Power Stroke Diesel 7 03-14-2016 08:13 PM
Colorado 2015 Garden Spyder Kansas Chapter 8 02-02-2016 10:41 AM
Tonner's in Colorado and Hoists... white 66 1947 and Older Ford Trucks 13 01-31-2016 05:27 PM
Colorado 2014 Garden Spyder Kansas Chapter 103 11-10-2015 02:14 PM
Anyone running bulletproof egr cooler plus their air oil cooler conversion? amsk8er1983 6.0L Power Stroke Diesel 12 02-18-2015 11:08 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
