Making a parts list.
You also need the two that go to the fuel filter housing banjo bolt.
Someone said lifters but to do that you need access to the rear
of the engine and have to take that cover off to pull the branch tube.
So to do that your going to need a HPOP gasket set and a rear main
seal and the silly tool to install it.
Sean
Sean
thanks for all the input guys. When I do all of this it will be a cab off job that is why I am waiting until I return to Colorado the DIY auto center on FT Carson is amazing compared to the one up here on FT Wainwright. Is the rear main a common leak problem on the 6.0 or should i not even bother with it. Don't want to separate engine from trans if I don't have to.
So what I am understanding is that I should stop being lazy and spend the couple of extra hours and $ and just do the seal before i have to deal with it later.
