New BFG's thanks to the bad Michelins - Ford Truck Enthusiasts Forums
Old 07-23-2014, 01:19 PM
EricRom's Avatar
EricRom EricRom is offline
EricRom is gaining momentum as a positive member of FTE.
Old 07-23-2014, 02:03 PM
senix's Avatar
senix senix is online now
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
I have them as well. Came with the truck. This version is much better than the old BFG's.
Seem to work well with towing and clean out fairly well in the mud.
Old 07-23-2014, 03:52 PM
Iowa Ford's Avatar
Iowa Ford Iowa Ford is offline
Iowa Ford has a superb reputationIowa Ford has a superb reputationIowa Ford has a superb reputationIowa Ford has a superb reputationIowa Ford has a superb reputationIowa Ford has a superb reputationIowa Ford has a superb reputationIowa Ford has a superb reputationIowa Ford has a superb reputationIowa Ford has a superb reputationIowa Ford has a superb reputation
Eric was this the leftover truck with the cracked side walls ??
Scott, are yours 20's
Old 07-23-2014, 03:56 PM
senix's Avatar
Nope, DRW's don't come that size. I think I have 17" rims.
Old 07-23-2014, 04:06 PM
Iowa Ford's Avatar
Thanks for the reply Scott, I don't know any thing about the duallys.
Just curious what size were on your dually.
Wonder if they quit using the Michelins ?
Old 07-23-2014, 04:08 PM
senix's Avatar
I think the Fx4 models come with the BFG's as standard.
Mine is aFx4.
Old 07-23-2014, 04:21 PM
Iowa Ford's Avatar
OIC, My 12 SRW FX4 came w/ the Michellin's and I don't Have any complaints. when I had a few miles on it I took it to tire shop and they said they were Excellent tires but toe in was off a bit. they must have been right cause the un-even wear on right front is gone. I'm Happy !!!
Old 07-23-2014, 05:45 PM
Lastwagen's Avatar
Lastwagen Lastwagen is offline
Lastwagen is starting off with a positive reputation.
Same here... the Michelin's on my FX4 should be good for 40k or more. I'm rotating at 6k. Depending on driving habits some are getting 50k. I'm sure the BFG's are good tires too. I don't like tires that pick up rocks. These Michelin's won't grab anything larger than pea size but I've had some tires pick up marble size and larger depending on the tread of course.
Old 07-23-2014, 09:29 PM
EricRom's Avatar
Yes it was. My father in law put a little pressure on the tire rep and gladly replaced them with the KO's because Michelin owns BFG.
Old 07-28-2014, 12:00 PM
caverjoe's Avatar
caverjoe caverjoe is offline
caverjoe has a very good reputation on FTE.caverjoe has a very good reputation on FTE.caverjoe has a very good reputation on FTE.
Thanks for the info. I am not at all impressed with the Michelin's. I thought they would be a plus when I bought the truck but I just turned over 30k on the truck and they are looking pretty wore. I do 95+% hwy and town driving. I pull a small enclosed trailer, but that should not matter much. I was sold on Yokohoma Geolanders for my old 99 and at 50k they would look just as good or better than these Michelin's at 30k. Same driving style. I usually rotate every oil change.
'55 panel build sstephanuik 1948 - 1956 F1, F100 & Larger F-Series Trucks 146 02-16-2017 01:53 AM
77 f350 427fe crew 8ft bed to see daylight in years winginit 1973 - 1979 F-100 & Larger F-Series Trucks 33 01-18-2017 09:37 PM
Fun in the woods tstone712 1973 - 1979 F-100 & Larger F-Series Trucks 6 11-02-2015 09:13 AM
G'day to all from Australia. Big G71 New Member Introductions 3 10-08-2015 08:49 AM
59 f100 - too far gone? Hobby welder 1957 - 1960 F100 & Larger F-Series Trucks 9 02-07-2015 06:44 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
