Acts like it was running out of fuel? - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 07-23-2014, 01:03 PM
Royson12's Avatar
Royson12 Royson12 is online now
Royson12 is starting off with a positive reputation.
Driving down the road, 1/2 tank of fuel, it acted like it was running out. I switched to a full tank, it straightened up. It usually goes to 1/4 before it does that. I do have the same old dip tube problem. But could that cause it to lose fuel at 1/2 tank? Another symptom in having is truck runs like a vat out of hell sometimes, and like hell other times? It has 230,000 on the original HPOP. Could that be on its way out?
Old 07-23-2014, 01:24 PM
madpogue madpogue is online now
madpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to behold
Maybe more of the pickup tube has rotted away, so it's starving at 1/2 tank now. You've been needing to pull that pickup out of the tank anyway; I think your truck is just telling you it wants you to do it now.
Old 07-23-2014, 01:40 PM
Royson12's Avatar
Sounds like my weekend is planned out now! Lol. What's the best way to fix it?
williameub williameub is offline
williameub is starting off with a positive reputation.
Quote:
My truck does the same thing. Some days it runs fantastic and other days It seems like a total dog.
The symptom isn't temperature related, although it does seem that after a good long run at 75; the truck preforms better for a couple of days after.
I'm interested on what the gurus can come up with
Old 07-23-2014, 02:59 PM
Royson12's Avatar
Mine will run like crap, and then an hour later, on the same trip, it will start running like a scalded ape, the back to crap again. Back and forth. I don't know much about these electronic trucks. Kinda miss my good ole idi. Easy to diagnose!
Old 07-23-2014, 03:02 PM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE MOOSE_MACHINE is offline
MOOSE_MACHINE has a good reputation on FTE.MOOSE_MACHINE has a good reputation on FTE.
X2 on that. The old idi was pretty easy. Ip, gp's or relay, return lines. That was about it
'91 F250 Acts like running out of fuel on the road. guru4sail Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 7 12-15-2016 05:37 PM
08 F250 Fuel Problem HELP 08lft250 1999 to 2016 Super Duty 5 11-26-2014 02:07 PM
1993 Ford F150 SuperCab 4x4 I6 5 Speed Sputtering. skers90 1987 - 1996 F150 & Larger F-Series Trucks 0 07-16-2014 12:55 PM
91 dual tank, Sputtering from both tanks now Youngbearman 1987 - 1996 F150 & Larger F-Series Trucks 1 08-23-2008 02:15 PM
Dual fuel tank problem Saintelias 1987 - 1996 F150 & Larger F-Series Trucks 8 09-03-2004 10:34 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
