Cig lighter replacement with power plug - Ford Truck Enthusiasts Forums
2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Old 07-23-2014, 12:48 PM
steveg_nh steveg_nh is online now
steveg_nh is starting off with a positive reputation.
Hi All - my first post, so hopefully I get it right. I'm enjoying my new 2014 Expedition Limited. This is my first Ford, and so far I'm loving it. Had a Nissan Armada before this, and always GM trucks before.
Anyway, I'm one of those guys that flips through the owners manual to see if there's any cool things I might have not otherwise known about. I read a note about not using the cig lighter plug for any 12v accessories, only a cig lighter. I read a lot of posts here after searching, and see it's mostly due to a lower rating on the outlet, and a more shallow cavity.
I'm kind of surprised there is even a cig lighter int he first place. I'll certainly never use it. Can it easily be replaced with a regular power outlet? Or can I safely use it as a 12v accessory plug, as long as I'm not overloading it (would be just for cell phone charging, as the truck has Navigation).
I couldn't find much on later model Expy's on removing the plug and swapping out.
Any insight is appreciated.
Thanks!
F450 OBDII port is dead KMcCullah 1999 to 2016 Super Duty 6 12-22-2015 12:36 AM
cigarette lighter and horn problem Lewis90i6 1987 - 1996 F150 & Larger F-Series Trucks 0 11-19-2013 10:34 PM
'03 F250 cig. lighter 919rider 1999 to 2016 Super Duty 3 01-03-2013 03:06 AM
Cig lighter and/or Power point/port fuse? MCDavis 2004 - 2008 F150 11 11-04-2011 07:53 AM
power outlet problem slkc Expedition & Navigator 11 12-28-2006 02:55 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
