What is this in my coolant filter? - Page 2 - Ford Truck Enthusiasts Forums
Old 07-24-2014, 03:08 PM
clem1226's Avatar
clem1226 clem1226 is offline
clem1226 is a splendid one to beholdclem1226 is a splendid one to beholdclem1226 is a splendid one to beholdclem1226 is a splendid one to beholdclem1226 is a splendid one to beholdclem1226 is a splendid one to beholdclem1226 is a splendid one to beholdclem1226 is a splendid one to behold
Quote:
Originally Posted by insolution View Post
Steve, can you elaborate on what your symptoms were and what exactly you did to resolve the issue? I have never delved in to the oil cooler... --Scott
My only symptom was a plugged coolant filter.
To fix my issue I rebuilt the oil cooler. It is located on the drivers side of the block; above the pan, below the power-steering pump. It is a long cylinder that bolts to the block and the oil filter spins on to the rear end of it. The two ends press on to the center tube section and the coolant and oil are USUALLY kept separate by 4 orings.
Do a search for oil cooler rebuild in this forum and you should come up with a thread by Cody aka Cleatus that has a great video.
I don't mind doing the leg work searching and posting links but I am on the road right now and I have found the iphone app pretty lacking for anything other than basic posting.
Old 07-24-2014, 04:38 PM
varminthunter243 varminthunter243 is offline
varminthunter243 is starting off with a positive reputation.
the dex cool did always seem to be much worse about sludging. I guess the fords were just really dirty. I've never owned a vehicle new enough to use the long life coolants until a year ago. but my wife's '10 escape is under warranty for a long long time so it's just so much easier to just take it to the dealership and say here, fix it haha so I haven't wrenched on it at all. those days when I was working at Valvoline and jiffy lube while I was in college are the limit of my experience with long life coolants
There has to be a solution to this.. Jeremy2792 6.0L Power Stroke Diesel 26 05-29-2016 09:03 AM
03 Sport Trac radiator crud av8tor09 Explorer, Sport Trac, Mountaineer & Aviator 3 08-26-2015 04:21 AM
cleaning crankcase of 4.6 Dewdzilla 1997 - 2003 F150 3 07-15-2013 04:52 PM
Coolant goes in oil pan when pressure testing rjdavis21 1999 - 2003 7.3L Power Stroke Diesel 20 07-28-2009 08:40 AM
2.3L Duratec Coolant loss xlt4me Ranger & B-Series 6 01-01-2007 08:19 PM
Tags
coolant contamination, coolant filters, coolant flush
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
