1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
7500 on an oil change....who does that?
Old 07-27-2014, 11:26 AM
idiabuse's Avatar
idiabuse
idiabuse is offline
Originally Posted by bucci
Was this ever addressed or commented on by idiabuse? This post is exactly why I don't use a by-pass system anymore with in between filter changes and oil analysis. To each his own though.
If I remember correctly, that '69 is red isn't it?
the only reason I take oil samples on my own diesel these days is to check for coolant leaching into my sump oil, I don't worry if my oil needs changing anymore, because if my oil needs changing I have to repair my engine.
It really is that simple now that I started with a new engine a few years back...
  #62
Old 07-27-2014, 11:31 AM
Hotpocket's Avatar
Hotpocket
Hotpocket is offline
Originally Posted by Tom
Yeah, I just don't buy that. Especially because fleets have maintenance programs to make sure stuff like that gets done. He probably has never done it, but someone most certainly has.
Our fleet vehicles at work get their oil changed every 7,500 miles.
I'm sure they changed it in the first 100,000,,,,I meant he never changed it in the last 200,000.
  #63
Old 07-27-2014, 11:34 AM
idiabuse's Avatar
idiabuse
idiabuse is offline
In the eight months since switching oil brands, installing off-line filters and ramping-up its oil analysis program, Schmid has noticed that lubricant and maintenance costs have gone down. In particular, new oil and filter purchases and disposal costs have been significantly reduced.
When this program started, everyone wondered if it would be cost-effective. “Our mechanics said ‘we sample every 250 hours and 10,000 miles on the engines and never seem to see a big change,’” Winberg said
The day it all began to fall into perspective was when high levels of potassium and positive glycol were reported on a scraper engine oil sample. Taking the lab’s advice, mechanics resampled the engine at 100 hours with the same results (Figure 3). The equipment was immediately shutdown and inspected to determine the root cause, which was found to be a blown head gasket. The repair bill for the head gasket was $400 and saved a $15,000 engine, all because of oil sampling
  #64
Old 07-27-2014, 11:56 AM
AlaskanEx's Avatar
AlaskanEx
AlaskanEx is offline
Bleed Ford Blue
I do full synthetic and motorcraft filters, i've been changing every 6-7k miles, i feel pretty good with that and i'm sure i could go further and may try it in the future.
  #65
Old 07-27-2014, 12:07 PM
idiabuse's Avatar
idiabuse
idiabuse is offline
Imagine going the opposite direction, and the pros call it cheap insurance!
  #66
Old 07-27-2014, 12:33 PM
bucci's Avatar
bucci
bucci is offline
That's with fleets. The company I drive for has a couple hundred 10 wheel tractors and they do oil analysis and what you described above and I bet it pass off for them too.
I have 2 vehicles. When I did the Amsoil by-pass with EA filters and ASL oil with analysis I only had one vehicle which was a gasser; Now I just change twice a year which is about 6,000 to 7,500 mile intervals.
  #67
Old 07-27-2014, 12:46 PM
idiabuse's Avatar
idiabuse
idiabuse is offline
It is easier to change 2x a year than drive 2 years with no change?
You stated you used ASL and bypass filtration, this is a proven winner and I have gone way over 25,000 miles with AMSOIL with great UOA reports.
just wondering I had to reap your reply a few times...
  #68
Old 07-27-2014, 01:28 PM
bucci's Avatar
bucci
bucci is offline
Two years oil changes cost me about $160; that's 4 oil changes; 24,000 - 30,000 miles in two years.
its $194 for 2 changes in 2 years for just the ASL oil and 2 EA filters; not including the by pass filter or oil analysis or the initial cost to install the bypass system.
I couldn't go much more than 32,000 miles with bypass because of low TBN. I am a short trip, mostly city miles type driving.
Edit: Want to add that with out bypass and just ASL with EA oil filter and air filter I was around 12000 miles with low TBN and high viscosity, it was awhile ago but I think viscosity was near 40 weight or over, not sure though, cant remember.
  #69
texastech_diesel's Avatar
texastech_diesel
texastech_diesel is offline
Token Redneck
Anyone have a series of UOA's on a 6.0 that shows the oil shearing? The biggest reasons I do 5k intervals in my truck is 1) changing from 5W40 to 10W30 or 0W40 in the winter, and 2) all the talk about viscosity getting hammered by the injectors.
$100 of T6 and a filter at 5k instead of 10k is a LOT cheaper than 8 injectors at $220 a pop, plus o-rings and misc parts to replace them. Obviously not a problem on the gassers or new common rail diesels.
  #70
Old 07-27-2014, 05:15 PM
idiabuse's Avatar
idiabuse
idiabuse is offline
Yes this one was our first sample with 10,000 or so miles
We left it in and sampled again at 22,000 miles, oil was still good to go.
I have to find that other sample sheet to share, meanwhile here is this one>>>
  #71
Old 07-27-2014, 05:20 PM
onedcharette's Avatar
onedcharette
onedcharette is offline
Full synthetic every 5k. Hoping its a value add....
  #72
Old 07-27-2014, 05:26 PM
idiabuse's Avatar
idiabuse
idiabuse is offline
blind trust in advertising and popularity, similar to sheep
  #73
Old 07-27-2014, 05:45 PM
kd0axs's Avatar
kd0axs
kd0axs is offline
Using full synthetic oil and changing it at 5000 miles won't gain you anything except a lighter wallet.
Sent from my HTC ONE using IB AutoGroup
  #74
Old 07-27-2014, 06:11 PM
onedcharette
A lil judgmental???
  #75
Old 07-27-2014, 06:34 PM
A/Ox4's Avatar
A/Ox4
A/Ox4 is offline
9 ECHO 1
If you (or anyone else for that matter) wants to change the oil at 5000 miles, or really even 7500, you can go with a convetional oil unless you need low weight oil for the winter.
Changing synthetic at 5000 is like pouring money down the drain.
Quick Reply: 7500 on an oil change....who does that?
