Another tuner thread, but different.
on
I didn't post an image, the only image that I'm aware of in this thread is for the MM only (which I didn't post), I'm talking about the Bully Dog device not the MM. I never heard of them, so I have to wonder if they are a relatively new device.
on
Apparently this seems to be a quirk of the MM tuner. I'm not to sure why that is. I can certainly see the pros and cons to it, but why only on that one vehicle. I didn't find any stipulation (doesn't mean that it wasn't there, I just didn't see it) in the online manuals for the Bullydog and Edge tuners that I believe were the equivalent to this one.
I don't have a tuner but I do have a GPS and the Edge Insight.
I leave these on the windshield at all times locally (remove them if I'm at a hotel or airport though).
Both of my devices are in direct sunlight at work all day.
The new Garmin Nuvi I have enters protect mode due to heat since it always has power but my old Nuvi would stay on 24/7 in heat or cold.
I've only had one GPS self destruct. It burst open and ripped out internal ribbon cables in 2008. Expensive but I chose not to change my behavior.
I don't have a tuner but I do have a GPS and the Edge Insight. I leave these on the windshield at all times locally (remove them if I'm at a hotel or airport though). Both of my devices are in direct sunlight at work all day. The new Garmin Nuvi I have enters protect mode due to heat since it always has power but my old Nuvi would stay on 24/7 in heat or cold. I've only had one GPS self destruct. It burst open and ripped out internal ribbon cables in 2008. Expensive but I chose not to change my behavior.
I took mine out after 3 weeks of having it in after I did the delete. I don't live in a bad area, but I am not going to risk somebody breaking my window and just taking the tuner. Not that they would be able to use it, It would just suck to have to go through that process. Nothing changes except for the power level. You are running the truck on "stock" power when you remove the Minimaxx. It will run for a couple of cycles on the last known power setting, but will revert to stock once the tuner is removed. I am not as much worried about temperature as I am somebody stealing it. Plus I don't need the power. I find that I am looking in the side view mirrors watching the smoke too much when I have it plugged in. Great question though. Reps sent brother!
I was really just curious about what others were doing with their tuners in reguards to weather conditions but looks like no issues have surfaced as far as the MM not holding up in extremes. especially up there where Brett is living with the polor bears ha.
I was wondering about that, if you have it unplugged for a while if you half to go back in and put all the defuel levels back to the way they were before you unplugged it. I don't know cuz I have never driven it without the MM plugged in.
on
As far as I know there is no battery within the MM head unit... the reason why GPS and phones explode when left in the sunlight in a hot automobile interior is because these days typically they have a prismatic Li-Po battery pack in there.
I used to have a lower end Scangauge clone which had a STN monochrome 20x2 character display that would have funky contrast if it was left in the sun, the active matrix colour display on the Mini Maxx doesn't seem to suffer from that at all.
#30
mtgrzlyman
03-05-2006 12:17 PM
JJFIVEOH
01-29-2006 05:01 AM
