want more low end torque out of stock 5.8 - Ford Truck Enthusiasts Forums
Old 07-23-2014, 05:53 AM
Ryan Colpitts Ryan Colpitts is offline
Ryan Colpitts is starting off with a positive reputation.
I'm looking for ideas to get some for low end out of my stock 93 F150 with 5.8, I own a 25ft travel trailer that it does haul OK but i'd like to get a little more pull out of it. Just looking for some basic ideas where to start I appreciate anyone's advice.
Old 07-23-2014, 07:37 AM
Conanski's Avatar
Conanski Conanski is offline
Conanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant future
Longtube headers with a single 2.5" exhaust and 1.7 roller rockers.
Old 07-23-2014, 07:57 AM
turnkyle turnkyle is offline
turnkyle is starting off with a positive reputation.
If you have 3.55 gears in the axles you could always regear to 3.73 or 4.10 gears.
Old 07-23-2014, 08:10 AM
I thought about gears but I did still want to keep my highway speed 3.73's mite be ok. I was thinking upgrade the stock ignition is pretty simple any suggestions on that?
Old 07-23-2014, 09:12 AM
garthneddy's Avatar
garthneddy garthneddy is offline
garthneddy is gaining momentum as a positive member of FTE.
Throw in a timing set that allows you to advance the cam timing.
Old 07-23-2014, 09:37 AM
1993_f350_2013's Avatar
1993_f350_2013 1993_f350_2013 is offline
1993_f350_2013 is gaining momentum as a positive member of FTE.1993_f350_2013 is gaining momentum as a positive member of FTE.
Quote:
How much will that add?
Old 07-23-2014, 09:44 AM
Greg5OH Greg5OH is offline
Greg5OH is starting off with a positive reputation.
that will move your pwoer band up or down. Littel trick the mustang guys use in the stock classes. Advancing it 4 degrees should bring your peak torque lower in the rpm range.
Old 07-23-2014, 10:57 AM
krooser's Avatar
krooser krooser is offline
krooser is gaining momentum as a positive member of FTE.
There isn't any free lunch. What adds on the bottom end will take away on the top end.
Anytime you modify the engine from stock you'll be making a compromise in fuel economy, performance, reliability or ??? I'm not saying don't do it but many times you'll not get the expected/advertised performance gains.
Changing the rear gear is one way to gain more low speed oomph at a cost of some fuel economy. Only you can determine of the benefit outweighs the cost. I may go the other way… installing a higher gear ratio to replace the 4.10's in my F350 in an effort to increase the MPG. A 460 is thirsty regardless but a couple MPG over the long haul may help.
Will I ever repay the $$$ I spent changing gears? Probably not… but I don't have to rely on my truck as a daily driver.
Old 07-23-2014, 12:05 PM
ya my truck isn't a daily driver it's a take out for weekend cruise or haul the trailer to the campground 4 or 5 times a year. I like the idea of having a little more getup in the low end I like to feel it pull if I want to step on it when i'm out for a little sunday drive.
Old 07-23-2014, 12:10 PM
Conanski's Avatar
What size tires are on the truck? If they are any bigger than stock then you really should put gears in it... or put stick sized tires back on.
Old 07-23-2014, 02:23 PM
just stock tires not sure right off what size.
5.0 coil to 5.8 coil is there a difference? Armytruckchuck 1987 - 1996 F150 & Larger F-Series Trucks 1 09-09-2016 12:00 PM
5.0 to 5.8 swap 1Austin112 1987 - 1996 F150 & Larger F-Series Trucks 34 02-10-2016 08:23 PM
5.8 Van Power Class C Power 1968-2013 Full Size Vans 11 08-20-2015 10:12 AM
1.7 rockers buzzy613 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 36 10-31-2013 06:37 PM
'96 5.8 mild build recommendations Txranger79 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 8 08-20-2013 03:26 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
