what gives now I have less power - Ford Truck Enthusiasts Forums
Old 07-22-2014, 11:41 PM
tofargone's Avatar
tofargone tofargone is offline
tofargone is starting off with a positive reputation.
Hi everyone.
I just did a lot of work to my truck and now it has less power than before I used to be able to scare the wife with no trouble now I can't did I forget to do something. I expected to have a few more ponys not less
04 6.0 f250. 210,000 miles xlt. edge chip that it has had since I bought it.
I did a 3.5" down tube to a 4" straight pipe .
Blue spring upgrade
Egr delete. I left the valve in instead of the block off plate and it is plugged in.
I rebuilt the turbo and had the heads rebuilt.
ARP studs.
Replaced the Pistons with oem
All the gaskets ( o rings )with oem
Both fuel filters
Coolant flush
Oil change
New Map sensor
new oil cooler.
And I scrubbed the heck out of the entire engine bay and all parts that came off.
I'm thinking I will unwire the edge chip after work to see if that changes anything.
Any ideas would be great.
Old 07-22-2014, 11:44 PM
tofargone's Avatar
Everything is plugged back into the Wright spot I took lots of pics and used a lot of tape and sandwich bags to label everything as it came off
Old 07-23-2014, 06:10 AM
78fordman's Avatar
78fordman 78fordman is offline
78fordman has a good reputation on FTE.78fordman has a good reputation on FTE.78fordman has a good reputation on FTE.
You replaced all 8 pistons? Total rebuild with machining or just some new parts to freshen things up?
Sent from my leash using IB AutoGroup
Old 07-23-2014, 08:02 AM
tofargone's Avatar
Just new pistons one was damaged the cylinder walls still had the cross hatching in them so they were in grate shape
Old 07-23-2014, 09:16 AM
04badford 04badford is online now
04badford has a spectacular reputation.04badford has a spectacular reputation.04badford has a spectacular reputation.04badford has a spectacular reputation.04badford has a spectacular reputation.04badford has a spectacular reputation.04badford has a spectacular reputation.04badford has a spectacular reputation.04badford has a spectacular reputation.04badford has a spectacular reputation.04badford has a spectacular reputation.
did you replace stand pipes and dummy plugs? Are you making Boost? may do a compression test . got any Gauges to read live Data?
Old 07-23-2014, 10:23 AM
tofargone's Avatar
No I didn't replace the stand pipes or the dummy plugs. I don't have any live feed gages I am working on getting a set but it will have to wait for a paycheck or two I just spent the reserve on the truck and the boost is good got up to 24 psi last night. It is surging though you can hear it in the exhaust and in the turbo when I'm causing at 75 it is bouncing between 12 and 16 constantly changing
Old 07-23-2014, 10:38 AM
Bullitt390's Avatar
Bullitt390 Bullitt390 is offline
Certified Thread Hijacker
Bullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant future
Misaligned y-pipe or a flex joint cracked during installation.
Josh
Old 07-23-2014, 10:44 AM
MC5C MC5C is offline
MC5C has a very good reputation on FTE.MC5C has a very good reputation on FTE.MC5C has a very good reputation on FTE.
I don't see anything you did that would increase power, you should have about exactly what you had before. I'd double check for exhaust leaks, and check the turbo boost level to make sure it can get up to 28 psi.
Brian
Old 07-23-2014, 11:12 AM
69cj's Avatar
69cj 69cj is offline
69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future
Quote:
Brian
28 is the max boost. Not every truck will get there. Average is probably 24 to 26. Ford considers 21 acceptable all though on the low side. I'm more concerned with tha occilating boost while cruising. At his speed my truck is just under 10 and steady.
Old 07-23-2014, 02:28 PM
tofargone's Avatar
The y pipe was a big pain to get lined up I'll double check it to see if it is all lined up or eeven if it cracked out wile I was bolting it up. But if there was a leak wouldn't you here it?
Old 07-23-2014, 04:32 PM
9228.bobcat's Avatar
9228.bobcat 9228.bobcat is offline
9228.bobcat has a great reputation on FTE.9228.bobcat has a great reputation on FTE.9228.bobcat has a great reputation on FTE.9228.bobcat has a great reputation on FTE.
May need tool do the turbo vgt relearn.
Old 07-23-2014, 04:41 PM
tofargone's Avatar
Quote:
How do I do that
Old 07-23-2014, 04:51 PM
Get up to normal op temp. Unhook batteries for 15 minutes with headlights on. Hook bats back up. Cycle key until seat belt light goes out, do that twice. Start engine let idle for 15 or 20 minutes then drive for 20 or so minutes. Pretty sure that's how, if my memory serves me right.
Old 07-23-2014, 05:02 PM
tofargone's Avatar
thank you I'll try that after work tonight
Old 07-23-2014, 05:03 PM
Yup. Hope it helps.
99.5 ford f350 7.3 need help Josh Swager 1999 - 2003 7.3L Power Stroke Diesel 23 07-08-2016 10:58 PM
So much work, so worth it.. kegomatix 1994.5 - 1997 7.3L Power Stroke Diesel 5 03-03-2016 08:37 PM
2007 250 6.0 #5 glow plug code Bran Hollywood 6.0L Power Stroke Diesel 4 02-05-2016 08:25 AM
looking for an Excursion.... Nsaan Excursion - King of SUVs 13 08-02-2012 09:42 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
