missing hose? - Ford Truck Enthusiasts Forums
missing hose?
Old 07-22-2014, 10:47 PM
now_what's Avatar
now_what now_what is offline
now_what is starting off with a positive reputation.
missing hose?
Hi was was hoping someone can help me out, I was hearing a sucking noise coming from the engine of my 1996 ford f250 7.5 V8 460 truck and i finally found out that it was coming from the pcv valve hose and a guy from Napa told me to just tape the end up because it was just a "t" connector that carries away fumes from the oil. so i taped it up and after taping it the noise was gone but i did notice a port on the engine that has nothing going to it so i was wondering is a hose from the pcv "T" suppose to go to the port on the engine the yellow arrow on the pic is the port and the red arrow is the "T" that's taped. is that right?
Old 07-23-2014, 06:48 AM
dixie460's Avatar
dixie460 dixie460 is offline
dixie460 has a good reputation on FTE.dixie460 has a good reputation on FTE.dixie460 has a good reputation on FTE.
That's the intake for the smog pump. It's supposed to be left open like it is now.
Old 07-23-2014, 08:05 AM
rla2005's Avatar
rla2005 rla2005 is online now
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
Quote:
X2 It's supposed to be open to the atmosphere like that
Old 07-23-2014, 04:31 PM
now_what's Avatar
Thanks a lot of the replies, SO the open port on the engine is the smog pump and that's suppose to be open like that right? Do you know anything about the pcv "t" Ive tried looking online and even had oreillys and Napa look and they cant seem to find anything that will work. so for now its just taped to stop the sucking. Thanks again I just want to make sure i understand it.
Old 07-23-2014, 05:09 PM
rla2005's Avatar
The photo above is not showing the PCV valve, that is the Canister Purge Valve (CANP).
One end goes to the intake manifold near the throttle body, perhaps on the throttle body I do not recall. And the other end goes to the charcoal canister. It's part of the evaporative emission system. The fuel tank vents to this canister most of the time. The computer commands the valve to open so the stored vapors are pulled into the engine.
Old 07-23-2014, 05:15 PM
now_what's Avatar
the red arrow in the picture is where I was told the pvc "t" is at and the yellow arrow is what i thought was missing a hose.
Old 07-23-2014, 05:43 PM
rla2005's Avatar
Quote:
The PCV does not attach to any part of the fuel tank vent system. The PCV has it's own vacuum line to the intake manifold, either at the back of the upper intake or at the manifold vacuum tree (there was a TSB to move it to the tree years ago).
Someone is feeding you false information.
Old 07-23-2014, 05:44 PM
now_what's Avatar
so everything in the picture looks normal and suppose to be that way? thanks again for the help.
Old 07-23-2014, 06:25 PM
rla2005's Avatar
No, that photo is not showing a normal installation. One end goes to the throttle body the other goes to the charcoal canister. The CANP sits in the middle.
Old 07-23-2014, 06:29 PM
now_what's Avatar
oh ok so if i take it to a shop they should be able to fix it? I would try but dont want to make it worse lol. thanks again.
Old 07-23-2014, 06:49 PM
danr1 danr1 is offline
danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.
You really should show us what each end of those hoses are connected to, you're saying PCV but as pointed out that system shouldn't have anything to do with it they are two separate systems.
Didn't even notice the red arrow at first, not clear what's going on there perhaps a picture at another angle and or one with the tape removed for clarity.
There should also be a sticker on the radiator support showing all vac line routing.
A simple google search for each item will provide a picture so you can verify any device you're not sure about, use the diagram to verify the vac system is as it should be. Any gray area just ask, don't know the name can't figure it out include a picture.
Old 07-23-2014, 07:02 PM
now_what's Avatar
ok ill take better pics and remove the tape. thanks again everyone for all the help.
Old 07-23-2014, 07:19 PM
Ok have a frame of reference now, that tee your red arrow points to goes to the pcv valve your yellow arrow points to and yes evap is connected to it.
My first impression that was the secondary air purge muffler too but it is not, image to up close to get solid bearing at first, took a minute to figure out what was what. The insulation first clue but at first didn't add up.. thought huh? and was thinking 302/351 but you did state 460!!
Vac to PVC from intake, vac passes beyond PVC valve to evap canister.
Get that tee down on there and you should be all set far as that goes.
rla2005's Avatar
A little late on my part but I would say no, do not take it to a shop. We can help....need some photos.
Old 07-23-2014, 09:27 PM
now_what's Avatar
here are some pics i took the first one is a pic of the tee without the tape on it and the second is on the port and the third is with the tee connected to the port. So is that the way it going?
For anyone who needs a MC2150 Vacuum port diagram Cedarghost 1973 - 1979 F-100 & Larger F-Series Trucks 6 03-09-2016 12:29 PM
K&N Cold Air Intake Question/Help now_what Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 13 09-01-2015 11:23 AM
over heating? now_what Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 10 10-06-2014 06:33 PM
Coolant temp gauge now_what Cooling, Heating, Ventilation & A/C 0 09-25-2014 09:58 PM
Help w/ Hose Part # kitebuz 6.0L Power Stroke Diesel 13 02-18-2012 07:01 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
