Android Tablet and OBDII - Ford Truck Enthusiasts Forums
Old 07-22-2014, 10:43 PM
Chris Snider's Avatar
Chris Snider Chris Snider is offline
Chris Snider is starting off with a positive reputation.
Ok fella's, I'm exhasuted from searching and still have not found my answer. I have an Android tablet and have downloaded the free versions of Dash Command and Torch Pro. Looking to Buy a wifi OBDII device of Amazon. Both apps give a lot of information,,,,, useless to me to know 1/4 mile in a 3/4 ton truck, what I don't see in either app is EGT temps. Is there a compatible wireless obdii device and android app that will give me that temperature without having to drill and tap my block to install a hard wired sensor?
Old 07-23-2014, 01:00 AM
Gearitis Gearitis is offline
Gearitis is gaining momentum as a positive member of FTE.Gearitis is gaining momentum as a positive member of FTE.
Rather than use my tablet, I bought a Scangauge II. For 150 bucks, by using the x gauge codes you an program it to monitor most of the EGT sensors. It was the least expensive way to do it without spending 1500 bucks. I tried the blue tooth dongle in the OBD II port and using apps. Just was not satisfied.
Old 07-23-2014, 08:12 AM
sdetweil's Avatar
sdetweil sdetweil is offline
sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.
the pids for those aren't in the android apps yet..
one of our members is working on them
see
http://www.ford-trucks.com/forums/13...ed-pids-2.html
and
http://www.ford-trucks.com/forums/13...que-pro-3.html
I am working on the plugin for TorquePro so later you won't have to type them in manually,
Old 07-24-2014, 04:06 PM
doczenith1's Avatar
doczenith1 doczenith1 is offline
doczenith1 is starting off with a positive reputation.
I bought this ODBII BT adapter and it is working fine with my tablet and Torque Pro.
Amzdeal V1.5 ELM327 OBDII OBD2 Bluetooth Wireless Car Diagnostic Interface Scanner - Bungee Cords - Amazon.com Amzdeal V1.5 ELM327 OBDII OBD2 Bluetooth Wireless Car Diagnostic Interface Scanner - Bungee Cords - Amazon.com
I should note that I bought the same adapter 3 years ago and it didn't work properly. The Torque Pro developer says the ELM327 adapters can be flakey. Not sure if I got a bad one or my phone was the culprit.
Torque App question mdb0531 6.7L Power Stroke Diesel 1 04-08-2016 12:28 AM
Moving OBDII App logs (and screenshots) to a PC Tugly 1999 - 2003 7.3L Power Stroke Diesel 0 02-16-2016 09:27 AM
BlueDriver Bluetooth Data for 1996+ TorqueKing 1987 - 1996 F150 & Larger F-Series Trucks 1 10-01-2015 10:57 PM
Which Bluetooth adapter? HT32BSX115 6.0L Power Stroke Diesel 12 08-04-2015 02:58 PM
mobile app problems 78fordman General NON-Automotive Conversation 34 05-10-2015 10:49 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
