2.7L EcoBoost 375HP and 375 lb/ft - Page 3 - Ford Truck Enthusiasts Forums
2015+ F150 Discuss the 2015 Ford F150 SPONSORED BY:
  #31
Old 08-13-2014, 04:23 AM
Frdtrkrul Frdtrkrul is offline
Frdtrkrul has a good reputation on FTE.Frdtrkrul has a good reputation on FTE.Frdtrkrul has a good reputation on FTE.
If Ford made the 5.0L EcoBoost, it'd be one bad powerhouse. My guess it'd be almost 650ft/lbs of torque. Though if it was offered in the SD line as well as the F150..wonder how that would affect diesel sales? I mean they just spent a lot more in the R&D for a larger turbo and exhaust brake. Plus with it being a gas burner instead of an oil burner, fuel costs will be down and maintenance costs will be much less...especially when one doesn't need 4 gallons of oil every 7500+ miles.
I have had the chance to test drive the 5.0L and the 3.5L EB at work for alignment checks and first impression they beat the crap out of the 2 valve 5.4L. So all I have to say is...SHUT UP AND TAKE MY MONEY! I want a 5.0L EB right now!
  #32
Old 08-13-2014, 06:19 AM
tseekins's Avatar
tseekins tseekins is offline
tseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputation
Quote:
Originally Posted by tvsjr View Post
I keep saying Ford needs to EcoBoost the 5.0 and make it an SVT motor. I'd buy one in a heartbeat. Assuming even 120lb-ft/L, that's 600lb-ft... sweet...
The latest edition of truck trend alludes to a bosted 5.0L code named VIPER, IIRC that will appear in the next gen Raptor trucks to replace the 6.2L.
  #33
Old 08-13-2014, 11:06 AM
RacinNdrummin's Avatar
RacinNdrummin RacinNdrummin is offline
RacinNdrummin is gaining momentum as a positive member of FTE.RacinNdrummin is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by IJAZ FAHTED View Post
You guys that already own the 3.5 Eco-Boost Ford lied to you both about the HP-Torque, and MPG so NOW you trust them with the numbers on the new 2.7 Eco-Boost?
You have absolutely no clue what you are talking about.
  #34
Old 08-13-2014, 11:15 AM
Quote:
He's a Chevy bailout lover, could you expect anything less?
  #35
Old 08-13-2014, 11:26 AM
My EB tows my 8000lbs excellent, gets 10mpg (right about what my IDI got under the same conditions), Empty I average 18mpgs in mixed driving. Freeway I usually average 21-22mpg at around 65mph. Biggest complaint I have is the soft suspension with the trailer on, its getting bags soon.
Im as happy as I thought I would be, if you expect any more out of a half-ton with a 3.5L engine and Auto in a 6K pound truck, your just an idiot who needs something to complain about.
  #36
Old 08-19-2014, 08:13 AM
tvsjr tvsjr is offline
tvsjr has a great reputation on FTE.tvsjr has a great reputation on FTE.tvsjr has a great reputation on FTE.tvsjr has a great reputation on FTE.tvsjr has a great reputation on FTE.tvsjr has a great reputation on FTE.
Quote:
I hope they offer it in non-Raptor varieties too (obviously, it would be top-range).
  #37
Old 08-19-2014, 02:40 PM
1saxman's Avatar
1saxman 1saxman is offline
1saxman is gaining momentum as a positive member of FTE.1saxman is gaining momentum as a positive member of FTE.
Just imagine the 2.7 EB in a standard cab and 6.5' bed with no trailer! That's what I'm thinking about - it would have to be a blast to drive and would do everything my 2007 does, like taking a load of cuttings to the landfill. Who needs a Raptor?
  #38
Old 08-28-2014, 08:20 AM
MotorCityAutomation MotorCityAutomation is offline
MotorCityAutomation is starting off with a positive reputation.
This engine will also feature ferrous-iron plasma spray coating for the cylinder bores, no cast iron jugs that are on the current 5.0L. Similar process for the 5.4L Cobra engines. Here's an article on the process Ford launches plasma-sprayed cylinder bores on 2011 Shelby V8 - SAE International
  #39
Old 09-06-2014, 08:40 PM
johndeerefarmer's Avatar
johndeerefarmer johndeerefarmer is offline
johndeerefarmer has a good reputation on FTE.johndeerefarmer has a good reputation on FTE.
Quote:
Originally Posted by Dr. Dirt View Post
I hope so too. people also forget about the price of diesel and the price of an oil change, fuel filters, and DEF compared to a good ol' gasoline engine service.
If you tow heavy or in hot conditions you have to run premium in the ecoboost anyway (and most people in the know recommend premium in the ecboost ALL of the time anyway); therefore the price of diesel is not any higher than premium pump gas. DEF is usually only needed about the time you change oil and a jug doesn't cost much. I also don't expect a small displacement diesel to take much more oil than a gasser.
Most every one that has towed with an ecoboost will agree that there is nothing "economical" about the ecoboost when it comes to towing fuel efficiency. It get's about the same as a big block NA V8.
If my F350 (which weighs several thousand lbs more and is way taller) can beat my old '13 ecoboost both unloaded and loaded mpg by 15-25% imagine what a smaller displacement diesel in the lighter F150 would do?
The only downfall to the diesel will be the upcharge over the price of the ecoboost. If they make it too expensive it will take a long time to pay for itself.
  #40
Old 09-11-2014, 08:33 PM
jntibs jntibs is offline
jntibs is starting off with a positive reputation.
Quote:
The Ram Ecodiesel 3.0 takes 10.5 quarts, so basically double a similar displacement gas engine.
  #41
Old 09-14-2014, 05:49 PM
jthorngate3's Avatar
jthorngate3 jthorngate3 is offline
jthorngate3 has much to be proud ofjthorngate3 has much to be proud ofjthorngate3 has much to be proud ofjthorngate3 has much to be proud ofjthorngate3 has much to be proud ofjthorngate3 has much to be proud ofjthorngate3 has much to be proud ofjthorngate3 has much to be proud of
Quote:
Originally Posted by jdadamsjr View Post
My wife complains about the mpg in hers too....
(but only when I drive it and it gets below her 21 mpg around dfw - so I reset it just before I coast into the garage )
but I can certainly attest to the 3.5 twin turbo being FUN in an Explorer Sport...
I get out of the 350 diesel which is not bad at all and jump into the wife's sport and WOW, I have to set the cruise because it WILL get away from you quickly...
and it's very nice that our only complaint in 20k+ miles is with the Microsoft Sync system !
I rented a truck while in Colorado a few weeks ago. Requested a fun50, but ended up with a dodge 1500. I can assure you, as I have sync in my car, that the uconnect they use is just the worst. It never understood what I said, I could barely tell what it said, and you had to download apps for it to work correctly, both with my phone and iPod.
  #42
Old 09-14-2014, 11:30 PM
super 6.8 super 6.8 is offline
super 6.8 has a good reputation on FTE.super 6.8 has a good reputation on FTE.
Wish they would announce the rpm's the hp and torque are made at. Have a running argument with a buddy that says the rpm's will be very high. I think not.
  #43
Old 09-15-2014, 07:30 AM
Tom's Avatar
Tom Tom is offline
Tom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputation
Quote:
You're probably going to be half right. Horsepower is a product of torque and RPM, which means peak horsepower will almost always be at a high RPM. The only way that can be different is if torque drops rapidly as you get into high RPMs.
Torque on every turbocharged engine I've ever seen peaks very low. That's done because forced induction allows engineers to setup engines to build boost at low RPMs and provide outstanding low RPM power. If it's anything like the 3.5L engine you can expect peak torque to be before 3,000 RPMs with the majority of that available before 2,000 RPMs. Smaller displacement doesn't change that formula; the turbocharged 1.4L engine powering our Chevy Cruzes at work have peak torque at 2,500 RPM.
  #44
Old 11-12-2015, 10:16 AM
pmac150's Avatar
pmac150 pmac150 is online now
pmac150 is starting off with a positive reputation.
2.7 power
All I can say is that my 2.7 xlt CC with a 6inch lift, SCT Live wire Tune with 35" Tires is giving me plenty of HP, & Low end Torque and still giving me 22HWY. Yes step on it and it will lower to 17mpg. Having the SCT Live Wire LCD Screen shows me the boost levels. Mostly it needs around 5-8PSI of boost to move around town and on the HWY holding 65-70mph, it shows 3-5 psi. of boost. at 80mph it shows 9-11psi of boost, thats when you are using a lot of gas 17-18.
W.O.T. tops out at 19.8PSI. per turbo.
Again, 6inch Lift., 20" Rims, 35" tires. And still pulls like crazy
  #45
Old 11-12-2015, 01:18 PM
seventyseven250's Avatar
seventyseven250 seventyseven250 is online now
seventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud of
That is some great real-world info, and I think pretty relate-able for a lot of folks to how they would use their trucks.
Also great point about the increased boost required at higher speeds. We all know aero drag is a huge mileage killer, but it's nice to see someone who has put some effort into documenting it.
Reps sent!
2nd Gen EcoBoost up to 450lb/ft torque Frdtrkrul 2015+ F150 42 07-12-2016 04:04 PM
2016 F150 New Engines? MKEBoost 2015+ F150 33 11-25-2015 08:13 AM
The Obligatory 2015 F-150 vs (Videos) 640 CI Aluminum FORD 2015+ F150 2 03-26-2015 06:10 PM
Question of the Week: Does 315hp make you want to buy the 2015 Edge Sport? Patrick R. General Automotive Discussion 5 02-10-2015 10:31 PM
2015 2.7L Ecoboost in Baja 1000!! PrinceValium 2015+ F150 35 01-25-2014 04:58 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
