2.7L EcoBoost 375HP and 375 lb/ft - Page 2 - Ford Truck Enthusiasts Forums
2015+ F150 Discuss the 2015 Ford F150
Old 07-25-2014, 12:23 PM
GuyGene's Avatar
GuyGene GuyGene is offline
GuyGene is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by tseekins View Post
Some people just don't know when to quit.
Did you really watch the videos? I don't put much stock in factory infomercials as they are always biased, but, I think Ford removed the bias here with offering three trucks and three drivers.
My Eco has 40K on the clock now and nary an issue. I'm getting a rock solid 20 MPG's in mixed driving. No need for me to lie, I didn't build it so my reputation isn't at risk here.
You mentioned chronic turbo issues on past vehicles, I believe you referenced a Sprinter Van and a Subaru. If these were your vehicles then the common theme is you and your abuse or lack of common sense maintenance. Frequent high quality oil changes and the prescribed or recommended filtration will mitigate those issues.
Now that's the ticket, Tim! I love these videos meself, but I know it's not totally unbiased, but still, I think it happened the way Ford showed it. My number one priority in any truck is reliability! My current '02 is reliable. One day, when I do get a newer truck, just think how much I'll be improving! I make these big jumps because I keep me trucks so long.
Old 07-25-2014, 02:44 PM
CGiron CGiron is offline
CGiron is gaining momentum as a positive member of FTE.
Orderbooks will open the 28 of July
According to
Ford-Lincoln Trucks (Build Out Final Order Start Up Dates)
If itīs correct I hope for figures of the MPG at the same time.
Old 07-27-2014, 06:09 PM
92F350CC's Avatar
92F350CC 92F350CC is offline
92F350CC has a brilliant future92F350CC has a brilliant future92F350CC has a brilliant future92F350CC has a brilliant future92F350CC has a brilliant future92F350CC has a brilliant future92F350CC has a brilliant future92F350CC has a brilliant future92F350CC has a brilliant future92F350CC has a brilliant future92F350CC has a brilliant future
A 2.7 V6 now makes significantly more power than my 5.8 does......
Excuse me while I go sit in my truck and cry.
Old 07-27-2014, 09:18 PM
efx4's Avatar
efx4 efx4 is offline
efx4 is gaining momentum as a positive member of FTE.efx4 is gaining momentum as a positive member of FTE.
I can't believe the Ram Ecodiesel was so far behind at the end, I guess 240 HP will do that compared to Ford's 325 HP. The Chevy 5.3 actually kind of kept up decently in the first 2 runs. I was impressed with Ford's honesty that the Chevy won by a few seconds when the temp went down. I sure hope mpg numbers come out soon, because the Ecodiesel seems to have the numbers to beat.
Old 07-27-2014, 11:08 PM
j.grif's Avatar
j.grif j.grif is offline
j.grif has a very good reputation on FTE.j.grif has a very good reputation on FTE.j.grif has a very good reputation on FTE.j.grif has a very good reputation on FTE.
Tis a quandary for old school car guys, I recently came across an article about how todays mini vans have equal performance to yesterdays sports cars, Soccer Moms' Revenge: Grassroots Motorsports this is troublesome until you realize that the minivan with all its prowess is never going to make you smile when you slide behind the wheel of what ever it is that you take care of, like your 5.8 Ford pick up, I know that my 79 trans am has way less torque and horsepower than this new 2.7, but the 2.7 will never for us at least be anything more than a tool or an appliance.
Old 07-28-2014, 10:11 AM
seventyseven250's Avatar
seventyseven250 seventyseven250 is offline
seventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud of
I own an Odyessy, and I can confirm it's pretty fast, although boring to drive. That's a great attribute on the highway though.
Old 07-28-2014, 10:47 AM
MotorCityAutomation MotorCityAutomation is offline
MotorCityAutomation is starting off with a positive reputation.
I have some insider news to share about the 2.7L Eco Boost, it will get duel injection for 2017 model. The cylinder head is being redesigned to accept a duel injection setup. The cylinder head will keep the direct injection but add normal fuel injectors to the intake manifold. The engineers are telling me that the engine will control which injection method to use based on the boost generated by the turbos. Unconfirmed is that the 5.0L Coyote engine platform will be getting a similar duel injection setup for late 2017 adding an EcoBoost option.
Old 07-30-2014, 02:06 PM
ssls6 ssls6 is offline
ssls6 is starting off with a positive reputation.
It's interesting when you think about what ford said on the 2.7L....they used lessons learned from the 3.5L. They don't say what lessons they learned but what we do know is this.
1) compacted iron block
2) offset rods
3) twin timing chains instead of one super long chain
4) an upgraded fuel management system
I also find this interesting
375 ft-lbs from 2.7L is 139 ft-lb per liter
420 ft-lbs from 3.5L is 120 ft-lb per liter
So the 2.7L eco has a higher power density than the 3.5L eco and would appear to be built stronger and react to fuel demands faster. Makes you wonder what a 2nd gen 3.5L would be like? 490 ft-lbs at the same power density?
Old 07-30-2014, 04:40 PM
I think it's typical for smaller engines to have higher "specific output". So it's probably not fair to expect the 3.5 to put out the same 139 ft-lbs/Liter as the 2.7.
However, it's an interesting thought, I know I wouldn't say no to another 30-50-70 ft-lbs . . . .
Old 08-10-2014, 08:41 PM
Soko179's Avatar
Soko179 Soko179 is offline
Soko179 is starting off with a positive reputation.
2015 tow test AWESOME Vid
Old 08-11-2014, 07:49 AM
jdadamsjr's Avatar
jdadamsjr jdadamsjr is offline
jdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputation
My wife complains about the mpg in hers too....
(but only when I drive it and it gets below her 21 mpg around dfw - so I reset it just before I coast into the garage )
but I can certainly attest to the 3.5 twin turbo being FUN in an Explorer Sport...
I get out of the 350 diesel which is not bad at all and jump into the wife's sport and WOW, I have to set the cruise because it WILL get away from you quickly...
and it's very nice that our only complaint in 20k+ miles is with the Microsoft Sync system !
Old 08-11-2014, 08:56 AM
RigTrash601's Avatar
RigTrash601 RigTrash601 is offline
RigTrash601 has a superb reputationRigTrash601 has a superb reputationRigTrash601 has a superb reputationRigTrash601 has a superb reputationRigTrash601 has a superb reputationRigTrash601 has a superb reputationRigTrash601 has a superb reputationRigTrash601 has a superb reputationRigTrash601 has a superb reputationRigTrash601 has a superb reputationRigTrash601 has a superb reputation
Quote:
Originally Posted by Gicknordon View Post
This guys posts so far have been mostly bashing ford and the new f150. Im not even gonna pay attention to what he says anymore.
Agreed, I'm with you on that........
  #28
Old 08-11-2014, 10:43 AM
Frdtrkrul Frdtrkrul is offline
Frdtrkrul has a good reputation on FTE.Frdtrkrul has a good reputation on FTE.Frdtrkrul has a good reputation on FTE.
Quote:
Originally Posted by IJAZ FAHTED View Post
You guys that already own the 3.5 Eco-Boost Ford lied to you both about the HP-Torque, and MPG so NOW you trust them with the numbers on the new 2.7 Eco-Boost?
*Cough* Chevy lover *cough*
  #29
Old 08-12-2014, 11:23 PM
tvsjr tvsjr is offline
tvsjr has a great reputation on FTE.tvsjr has a great reputation on FTE.tvsjr has a great reputation on FTE.tvsjr has a great reputation on FTE.tvsjr has a great reputation on FTE.tvsjr has a great reputation on FTE.
Quote:
I keep saying Ford needs to EcoBoost the 5.0 and make it an SVT motor. I'd buy one in a heartbeat. Assuming even 120lb-ft/L, that's 600lb-ft... sweet...
  #30
Old 08-12-2014, 11:49 PM
Quote:
X2, yes please!!!
2nd Gen EcoBoost up to 450lb/ft torque Frdtrkrul 2015+ F150 42 07-12-2016 03:04 PM
2016 F150 New Engines? MKEBoost 2015+ F150 33 11-25-2015 07:13 AM
The Obligatory 2015 F-150 vs (Videos) 640 CI Aluminum FORD 2015+ F150 2 03-26-2015 05:10 PM
The 2.7L EcoBoost V6 is the Best Engine in the 2015 F-150 edtahaney 2015+ F150 13 03-21-2015 08:14 PM
An interesting read on the 2.7L Eco tseekins 2015+ F150 7 01-25-2014 11:13 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
