So as long as the ECM/PCM sees .85V from the ICP it says start!
Once the truck is running if there is any fluctuation in the ICP value at an idle, the truck goes stupid/wacko. At least that is what happened to me when my ICP sensor decided to go **** up!
Does the ICP play any role during the drive cycle?
Thats correct.
The ipr is a metered oil leak back to the oil pan, any unused high pressure is dumped back to the pan.
The icp is just confirming what the ipr is doing
It must of been a looong day, from the notes the 0.2v that I was referring to was KOEO not start, so when you start Juicing the sensor at cranking .85+ BAM you get Diesel start. We need a kick my self in the Nads Icon
I thought we has enough of them being kicked in that other thread.
