Stacks or back exhaust? - Page 2 - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 07-24-2014, 07:07 AM
DIYMechanic's Avatar
DIYMechanic DIYMechanic is offline
DIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to behold
One thing to add to the fray is that generally with stacks you will end up with soot on whatever is nearby. Also, if you use a flat or mitre cut stack that allows water to collect in it, you will have all that sooty water blown all over your truck the first time you start it after a hard rain. I'm not a stack kinda guy, but to each his own. Personally I prefer a nice 3" downpipe to a 5" system that empies in the stock location. That's just my preference for look and sound.
As others have said, if you're going to do stacks, do it for the look and sound not for any expected performance difference because there won't be one.
Old 07-24-2014, 07:50 AM
Robbieo11's Avatar
Robbieo11 Robbieo11 is offline
Robbieo11 is starting off with a positive reputation.
Quote:
Originally Posted by fordpride View Post
This has to help with EGT's
Looks like a mobile pipe organ
Old 07-24-2014, 10:57 AM
BBslider001's Avatar
BBslider001 BBslider001 is online now
BBslider001 is a splendid one to beholdBBslider001 is a splendid one to beholdBBslider001 is a splendid one to beholdBBslider001 is a splendid one to beholdBBslider001 is a splendid one to beholdBBslider001 is a splendid one to beholdBBslider001 is a splendid one to behold
All the really matters is if the person that is putting them on his truck likes them. I had em on my 97 and they will be going on the dually and cN care less what anyone else thinks.
I hear what you're saying but he did ask opinions and that's what we gave him. In the end it only does matter if he's happy but it sounds like he was on the fence.
Old 07-24-2014, 11:08 AM
fordpride's Avatar
fordpride fordpride is offline
fordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant future
He asked about performance gains, not looks
Old 07-24-2014, 01:55 PM
Yep, I stand corrected. I still hate them...LOL! But yeah, to each his own. I hate them so much I would almost sacrifice performance, even if they were better...but that's just me.
Old 07-25-2014, 01:47 AM
cowmilker08's Avatar
cowmilker08 cowmilker08 is offline
cowmilker08 has a good reputation on FTE.cowmilker08 has a good reputation on FTE.cowmilker08 has a good reputation on FTE.
Do you guys think that a hood stack offers any kind performance gain? I would think maybe only a slight amount in higher horsepower trucks that move a lot of air (exhaust).
Old 07-25-2014, 11:04 AM
IDMooseMan's Avatar
IDMooseMan IDMooseMan is offline
IDMooseMan has a great reputation on FTE.IDMooseMan has a great reputation on FTE.IDMooseMan has a great reputation on FTE.IDMooseMan has a great reputation on FTE.IDMooseMan has a great reputation on FTE.
Phil, stacks don't offer any performance gain over the OEM routing. Consider that when adding stacks, one pipe is routed into two pipes. Generally with a double-90* turn, going to the left and right sides of the truck, and then additional 90* turns going up each stack. That's a minimum of 4 90* bends in the exhaust system.
I don't know what you mean by "hood stack," but that seems like a lot of sharp turns for the exhaust gasses to negotiate. Opening up the exhaust system is always better than the OEM setup. Stacks are just a different way to do that. They do offer better performance gains over an OEM system, but the do not offer better performance gains over a turbo-back system or a cat-back system. They're just use a different route and serve a different purpose.
Old 07-25-2014, 05:18 PM
strokin'_tatsch's Avatar
strokin'_tatsch strokin'_tatsch is offline
strokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud of
Quote:
What he means by "hood stack" is what you generally see on sled pulling or drag trucks. A stack in the hood of the truck, so exhaust only runs a couple feet max before going to atmosphere.
IMO, there can be a gain with a hood stack ONLY when the exhaust size being used is larger than you could have physically fit under the truck. On our hood stacks we are usually using a 4-5" pipe straight off the turbo and out the hood stack. Obviously, that's larger than what we are going to be able to build a downpipe with on most Powerstrokes. Dodges you can build a 5" downpipe for though. The hood stack itself is strictly for looks. Under the hood there is a pipe that is just blowing up into the stack. The stack and the pipe under the hood aren't physically connected.
OP, as far as stacks in the bed go... There will be zero performance difference. I have run a stack(s) on my OBS for about 8 years now. I have wished many times that I didn't do it, but there is nothing out there that is going to give me the same sound and it has benefits for me at the drag strip such as preventing me from "smoking the lights" (blowing the smoke up into the air instead of low to the ground where the smoke can blow forward and get in front of the timing lights).. Other than that, I like the look on some trucks and others I hate. On my truck, I like how the single 6" stack looks. I don't even care if Byron likes it or not. LOL
Old 07-25-2014, 10:17 PM
IDMooseMan's Avatar
That's what I was thinking he meant, but wasn't sure. Thanks for the education, Travis.
Stacks miakosn895 Exhaust Systems 0 10-23-2015 03:04 PM
Stacks and dirtbikes? Drewster2016 1999 - 2003 7.3L Power Stroke Diesel 3 03-29-2015 12:55 AM
to the stacks experts…. Snuggyworm 6.0L Power Stroke Diesel 2 11-10-2014 09:43 PM
Dual Stacks - Concerns or Complaints to be aware of? Tylus 1999 to 2016 Super Duty 107 09-30-2011 09:17 AM
Stacks Pros and Cons? JohnBrison 1994.5 - 1997 7.3L Power Stroke Diesel 19 07-24-2009 08:56 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
