Saving money for BPD oil cooler - Ford Truck Enthusiasts Forums
Old 07-22-2014, 09:03 PM
joe blow's Avatar
joe blow joe blow is offline
joe blow is gaining momentum as a positive member of FTE.joe blow is gaining momentum as a positive member of FTE.
I am going to pull the trigger soon and wanted some opinions good or bad from some of you guys that have/had it and seen results from installing this nice piece of equipment. All opinions are welcomed and appreciated.
I am going for the Tall HD cooler with oil filter relocation kit. Don't think I need the cold weather kit as I live in Socal and at my altitude, I rarely see temps below 40*F if that....but like I said any opinions are welcomed.
Thanks
Joe
Old 07-22-2014, 10:06 PM
Bullitt390's Avatar
Bullitt390 Bullitt390 is offline
Certified Thread Hijacker
Bullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant future
My opinion is you could replace the factory cooler 10 times compared to the price of one BPD kit.
Josh
Old 07-22-2014, 10:21 PM
Shaneb75's Avatar
Shaneb75 Shaneb75 is offline
Strokin Okie
Shaneb75 has a great reputation on FTE.Shaneb75 has a great reputation on FTE.Shaneb75 has a great reputation on FTE.Shaneb75 has a great reputation on FTE.
X2^^ replace the stock cooler and spend your $$$ on fun upgrades.
Old 07-22-2014, 11:11 PM
mustang_309's Avatar
mustang_309 mustang_309 is offline
mustang_309 is a splendid one to beholdmustang_309 is a splendid one to beholdmustang_309 is a splendid one to beholdmustang_309 is a splendid one to beholdmustang_309 is a splendid one to beholdmustang_309 is a splendid one to beholdmustang_309 is a splendid one to behold
X3 I think that is an enormous waste of money. Use the money for something else like a dieselsite HPOP when yours dies if it ever does.
Old 07-23-2014, 12:20 AM
jswartz84's Avatar
jswartz84 jswartz84 is offline
jswartz84 has a great reputation on FTE.jswartz84 has a great reputation on FTE.jswartz84 has a great reputation on FTE.jswartz84 has a great reputation on FTE.jswartz84 has a great reputation on FTE.
X4, the factory cooling system works great. I've read where some in warmer climates expected to see lower oil temps but didn't vs. the stock OC system.
Old 07-23-2014, 12:29 AM
joe blow's Avatar
Very interesting comments so far. No way is this a bash BPD thread....just opinion gathering
I agree it is a lot of money, that is for certain. There was an overwhelming majority agreeing one could replace the stock cooler 10x for the price of a BPD. I have been in the motor that far once and it is ALOT of work for sure. Do you guys constantly replace coolers in your trucks?
Just as a piece of mind for me that my oil cooler is working. Normal deltas unloaded range from 10-14*. Loaded and towing HEAVY the deltas stay close as mentioned but on long hard pulls I have seen spreads as far as 30* and coolant temps reaching ~235*.
I have been told I am ok so I closely monitor and it hasn't changed much. Is it time for a new cooler or is it working as it should?
Thanks
Old 07-23-2014, 12:37 AM
jswartz84's Avatar
In no way would I bash BP diesel. They make an awesome product, but a high price.
Sounds like you will need a new oil cooler shortly. Keep up with good maintenance of the cooling system and you shouldn't have to replace it again.
And make sure you use an OEM oil cooler kit
Old 07-23-2014, 08:20 AM
jsm180 jsm180 is offline
jsm180 has a good reputation on FTE.jsm180 has a good reputation on FTE.
What problem are you trying to solve with the BP cooler?
The stock cooler in a properly maintained vehicle works fine in warm and cold weather.
No long hoses to leak or burst. No oil filter waiting to be punctured by tire or road trash. No need for altered fan ops to improve airflow through the rad and ac condenser.
But I have heard they send some cool swag with the kit if you are into that sort of thing.
Old 07-23-2014, 08:25 AM
Zbugsii's Avatar
Zbugsii Zbugsii is offline
Zbugsii is starting off with a positive reputation.
I have the full BPD setup with bypass filter. Yes, expensive, but if you are traveling lots across the country, putting lots of miles on the truck, plan on keeping it for a long time..... then piece of mind takes it for me.
But at a very minimum, a coolant filter should be installed.
I also have several other upgrades as in:
Blue Spring ARP Studs, Modified Heads with pressed in valve guides
Bulletproof Oil Cooler, Oil Filter, & Amsoil Bypass Oil Filter, Aluminum Radiator, 4" SS Exhaust, Diesel Site HPOP, Coolant Filter, External Fuel Filter and Transmission Filter, Helwig Swaybars, Dash Boss Monitor with Fuel Pressure and EGT, Evans Waterless Coolant
Old 07-23-2014, 09:36 AM
KDAVID1's Avatar
KDAVID1 KDAVID1 is online now
KDAVID1 has a very good reputation on FTE.KDAVID1 has a very good reputation on FTE.KDAVID1 has a very good reputation on FTE.KDAVID1 has a very good reputation on FTE.
Quote:
Originally Posted by Zbugsii View Post
Blue Spring ARP Studs, ]Modified Heads with pressed in valve guides
Curious about the modified heads? Not to highjack--would like to know more.
Old 07-23-2014, 09:46 AM
Zbugsii's Avatar
Well, standard heads are just casted metal and the valve guides are just the same metal as the casting. Thus, they can and do crack and wear more. So, when having the ARP studs installed and as part of the package, they recondition and check the heads, grind out metal and press in "hardened" valve guides in their place. If you go to Bullet Proof Diesel web site, they have some links to some write ups and articles with a description and pictures.
Old 07-23-2014, 09:49 AM
KDAVID1's Avatar
Ok--I gotcha--thanks.
Old 07-23-2014, 10:26 AM
gregory1420 gregory1420 is offline
gregory1420 is starting off with a positive reputation.
i have the full kit also.. been on my truck since dec of 2012. the filter is easy to get to. i like it so far only prblems i've had is one of the hoses has a slight hole rubbed thru it bc of the way it was routed and the erg cooler is leaking where it goes up into the intake.
would i buy it again hard to say i might just flush the crap out of it and change the coolant to the cat EC then install a new cooler and leave it at that...but at the time i had the money and feel its a good upgrade for the truck..
Old 07-23-2014, 11:49 AM
joe blow's Avatar
- Can you elaborate on the altered fan ops please. Never heard of this.
- could give a $h*t less about the stuff included....I am more interested in longevity and possibly removing the possibility of a burst oil cooler which IMO is the worst thing to deal with. My friend dealt with it and it sucked.
Old 07-23-2014, 11:51 AM
Bullitt390's Avatar
Quote:
Originally Posted by joe blow View Post
- could give a $h*t less, more interested in longevity and possibly removing the possibility of a burst oil cooler which IMO is the worst thing to deal with. My friend dealt with it and it sucked.
OEM coolers do not have the reputation for bursting or rupturing. A handful of examples doesn't make an epidemic.
Josh
I just received and unboxed my BPD oil cooler and stuff joe blow 6.0L Power Stroke Diesel 58 10-28-2015 04:30 PM
Opinions on 5w-30 synthetic use in the 6.0L joe blow 6.0L Power Stroke Diesel 9 09-30-2015 06:41 PM
HPOP pump question joe blow 6.0L Power Stroke Diesel 6 09-19-2015 02:33 PM
Sounds like an ICP but looking for advice on potential problem joe blow 6.0L Power Stroke Diesel 22 09-04-2015 01:53 PM
Matching a turbo with new nozzles joe blow 6.0L Power Stroke Diesel 24 08-07-2011 01:06 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
