Just swapped e40d...not working - Ford Truck Enthusiasts Forums
Old 07-22-2014, 06:40 PM
jhyde01 jhyde01 is offline
jhyde01 is starting off with a positive reputation.
After blowing my old automatic E40D transmission, I just replaced it. I got a good deal on this new one with only 70k on it out of a working truck. I put in the new transmission, dialed in the torque converter, put on the transfer case, drive trains, filled with fluid to dipstick marker, and filled the transfer case. I put the truck in drive and reverse and nothing happens, but if I rev the engine up to about 3, it will start to grab and move and then it will release and grab again. It does this in 2 high, 4 high and 4 low.
I can't figure out what the problem is, the only thing I notice is the overdrive button no longer does anything, and the trans pan drips a little, but I think that's from the new gasket I put on it.
Anybody have any thoughts on what it could be? Could it be the transfer case?
Old 07-23-2014, 11:49 AM
mcdonaldm mcdonaldm is offline
mcdonaldm is gaining momentum as a positive member of FTE.
did you check the fluid level with the truck running in park? sounds like the fluid level is low. if the torque converter was not filled before you installed it, it will take a lot of fluid to refill it after it starts and this leaves little fluid in the pan to run rest of tranny.
rgds
Mike
Old 07-23-2014, 01:00 PM
Low fluid
The dipstick seems to be wrong as far as fluid level goes. I put a lot more fluid in and now it's running fine. So now I guess I just have to go by feel with how much transmission fluid I need in there.
PLEASE HELP 97 EXPEDITION E40D TO 4R100 SWAP decotrain 1997-2006 Expedition & Navigator 0 12-10-2016 10:01 AM
blocked vent tube on transfer case FSSF Clutch, Transmission, Differential, Axle & Transfer Case 6 10-05-2016 10:09 AM
Transfer case grind - only in reverse? Piginabag Clutch, Transmission, Differential, Axle & Transfer Case 9 12-09-2015 03:39 PM
Transfer case fluid and belt change f250mtnbikr 1999 to 2016 Super Duty 0 05-15-2015 10:26 AM
Trans & Differential Fluid Change Thumper47 Ranger & B-Series 5 11-08-2011 11:27 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
