5.0 to 5.8 swap, Need help on picking a tranny - Ford Truck Enthusiasts Forums
Old 07-22-2014, 06:04 PM
Shadow944795's Avatar
Shadow944795 Shadow944795 is offline
Shadow944795 is starting off with a positive reputation.
Alright so to do my 5.8 swap correctly based off what I know the curnet Mazda transmission has to go out of the truck and something that is stronger Needs to go in its place, now Preferable I would put a ZF-5 in there but as I have been told/figured out, its a rare item especially if the truck is two wheel drive like mine. So this leaves me stumped, I don't wanna break the bank or look around for months to try and find a good deal on a ZF-5 but honestly other than putting a C-6 auto behind the engine and calling it done I'm not sure what I should go with. I would like to maintain some form of overdrive for long trips but I do very few of them a year so it would not be a huge deal if I do not have it. When I do drive it its maybe a 25 mile round trip at the most and thats to work and back doing 55 miles an hour or more depending on how far in the gas I am . Like I say I'm not to sure and would rather be sure that what I'm getting is gonna fit my needs and still take the power of a 351 with a cam and gt40 heads. Best regards and thanks in advance, Shadow.
Old 07-22-2014, 06:42 PM
fordbuff91's Avatar
fordbuff91 fordbuff91 is offline
fordbuff91 is starting off with a positive reputation.
You can still use the Mazda transmission. it is not as heavy duty as the zf5, but as long as you don't beat the snot out of the truck you will be ok.
Old 07-22-2014, 06:52 PM
Quote:
Well that's kinda the thing, I might be doing some beating on it when I'm not actually using it as a truck and hauling stuff or just using it to take me to a few places the car does not reach without hitting the ground.
Old 07-22-2014, 07:11 PM
fordbuff91's Avatar
As long as you don't do clutch drops at every traffic light you will be fine. My stepfather had a 2wd 1988 f150 with the 300 I6 and Mazda transmission, he used to beat the hell out of it (burnouts with 32" tires, push starting a mack box truck, towing a tandem axle trailer loaded with rocks with a load in the bed as well.) it got sold for parts with over 300k miles on it when the body was about ready to fall off the frame. It still ran good and shifted good as well.
Old 07-22-2014, 07:54 PM
While that is a promising statement a 300 and and a 351w are in some ways a different animal but with story's like that I'm tempted to give it a shot and if I feel its starting to fail me or I bust the thing there will be a good solid replacement not far behind.
Old 07-23-2014, 08:29 AM
Conanski's Avatar
Conanski Conanski is online now
Conanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant future
Yeah don't bother changing the trans unless it actually starts giving problems, if you drive at all sensible I don't see a good M5 just crumbleing for no reason, and that should give you lots of time to track down a ZF or even a spare M5.
Old 07-23-2014, 11:07 AM
1993_f350_2013's Avatar
1993_f350_2013 1993_f350_2013 is offline
1993_f350_2013 is gaining momentum as a positive member of FTE.1993_f350_2013 is gaining momentum as a positive member of FTE.
Since it's 2wd could you use a mustang transmission..? Or is there a way to build a M5?
The Blue Goose's build thread. Shadow944795 1987 - 1996 F150 & Larger F-Series Trucks 91 11-23-2016 06:26 AM
93 F-150 351W to 302w (Yes I'm going backwards) Shadow944795 1987 - 1996 F150 & Larger F-Series Trucks 28 09-01-2016 04:54 AM
1993 F-150 with a Blown head Gasket. Shadow944795 1987 - 1996 F150 & Larger F-Series Trucks 0 04-09-2016 06:37 PM
Preping for the engine swap. Do's and don'ts? Shadow944795 1987 - 1996 F150 & Larger F-Series Trucks 5 10-18-2015 08:18 PM
Strange vibrations from the rear end Shadow944795 1987 - 1996 F150 & Larger F-Series Trucks 1 08-16-2014 10:20 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
