Duraspark 2 wiring harness with GM 4 pin IGN module - Ford Truck Enthusiasts Forums
Ford Truck Parts for Sale Ford Truck related Parts and Accessories for sale
Parts Search
Keyword:
Category:
Price:
Private or Vendor Listing:
Location (State):
Item Condition:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Location (State):
Old 07-22-2014, 05:48 PM
JimsRebel's Avatar
JimsRebel JimsRebel is offline
JimsRebel has a very good reputation on FTE.JimsRebel has a very good reputation on FTE.JimsRebel has a very good reputation on FTE.JimsRebel has a very good reputation on FTE.
Category: Engine - Electrical
Price: $30
Private or Vendor Listing: Private Listing
Item Condition: Used
Shipping Information: Item can be shipped
Engine: Part suitable for gas truck
Part fits:: 1980-1986
Just look at the pictures first......
This was my 1st gen Ignition module, but I made a different one with a different heat sink.
This would be something you could use to swap out the computer on a 1985-86 F150 with a 300 six. Really it will work on any DS 2 swap.
So what you are looking at is a GM 4 pin ignition module attached to a Ford remote style fender mounted heat sink used with an EEC IV Ignition module. The connector for the Distributor is about 20 inches long and connects to the Dist pig tail harness which is about 8 inches long.
The red and green wires are about 12 inches long.
The module is mounted with heat sink compound.
You can buy the GM IGN module from Autozone for $25-30 but the real value to this setup is the connectors and the simple installation due to the Distributor connector. You just cut the green from the coil and butt splice it. The red wire is connected to any 12 volt KEY ON source, I just use the Coil Positive.
The advantages of this ignition module setup are you don't need to try and find a stock DS2 harness. It will work with any coil including the stock square coil that is currently on your truck. It uses full voltage to the coil which is what you currently have on an EEC IV system.
You will need to find a place to mount the heat sink that has some air flow.
$30 plus $6 shipping USPS , $36 total is you send me a money order. Add $3 if you want to do paypal as a "purchase" as I really hate to give my money to paypal.
Ask if you have any questions.
Jim
Old 07-22-2014, 05:52 PM
JimsRebel's Avatar
here are some more photos.
Old 07-23-2014, 12:15 PM
1986F150six 1986F150six is offline
1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold
This is a very decent deal, folks. I have recently purchased the components to do this in case the MSD 6 AL box I am using fails. As stated, the 4 pin ignition module is $25-30 and the Duraspark connector runs about $20. Add that to the wire, connectors, tape and time [etc.].
Plus, with Jim's instructions, it is "plug and play".
Old 08-10-2014, 03:06 PM
JimsRebel's Avatar
This has been sold.
I am going to leave the post up to help others.
Jim
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Help with duraspark ignition Rulebreaker Electrical Systems/Wiring 32 09-25-2016 01:24 PM
Six Door Centurion F350 Powerstroke Project BrettMavriK 1987 - 1996 F150 & Larger F-Series Trucks 95 03-28-2014 11:16 AM
Duraspark Harness Connectors DIY KsCop '80-'86 FAQs (Frequently Asked Questions) 10 03-06-2014 11:42 AM
Duraspark II/HEI conversion failed sixofspades Ford Inline Six, 200, 250, 4.9L / 300 1 02-14-2014 09:23 PM
duraspark ll stator replacement fyi: 44nneedit 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 0 11-10-2012 07:20 PM
