Generator light staying on - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 08-07-2014, 07:10 AM
3414 3414 is offline
3414 is gaining momentum as a positive member of FTE.
No such thing as a one wire regulator. The one wire alternator has the regulator built into it, there is just one main connection, alternator hot to battery positive. There is a another connection if you want the indicator light to work.
Low budget is pick up a used Delco integral regulator alternator (one wire). Another low budget is to pick up a used Delco separate regulator (or Ford separate regulator) alternator complete with wiring harness and put it in.
  #32
Old 08-07-2014, 07:32 AM
Lahti35's Avatar
Lahti35 Lahti35 is offline
Lahti35 is starting off with a positive reputation.
Quote:
Originally Posted by 78 & 87 Super Cab View Post
I know, I am wanting to do this cheaper than 82 bucks
C&G has the generator repair kit for $30 (brushes, bearings, and a good quality armature made in england). I just did one, pretty easy and cheap as long as your field coils are still good.
  #33
Old 08-07-2014, 01:08 PM
78 & 87 Super Cab's Avatar
78 & 87 Super Cab 78 & 87 Super Cab is offline
78 & 87 Super Cab has a good reputation on FTE.78 & 87 Super Cab has a good reputation on FTE.
I'll check into it, thanks. I checked with a good friend of mine,and he just happened to have a few of them laying around, he just dropped one by so I'll be on the road soon
  #34
Old 08-08-2014, 08:32 AM
Forgot to ask, do I need to polarize this replacement one?
  #35
Old 08-08-2014, 08:53 AM
hiball3985's Avatar
hiball3985 hiball3985 is offline
hiball3985 is gaining momentum as a positive member of FTE.hiball3985 is gaining momentum as a positive member of FTE.
If you are putting a new generator on then YES to be on the safe side. If you don't you have a 50/50 chance of it being wrong.
  #36
Old 08-08-2014, 12:56 PM
Fired it up to see what it would do, and it's working great
  #37
Old 08-08-2014, 03:54 PM
Tedster9's Avatar
Tedster9 Tedster9 is online now
Tedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputation
Sweet! Voltages good?
Sent from my iPhone using IB AutoGroup
  #38
Old 08-12-2014, 10:09 AM
NoBowTiesHere NoBowTiesHere is offline
NoBowTiesHere is starting off with a positive reputation.
glad it worked.
How many generations of Ford trucks do you have? DieselCamper 1973 - 1979 F-100 & Larger F-Series Trucks 70 10-23-2016 10:08 PM
Alternator/generator light dimly lit once truck is started asmith6 1961 - 1966 F-100 & Larger F-Series Trucks 9 03-05-2016 05:34 AM
63 f100 generator issue Combatwombat 1961 - 1963 F100 Unibody 3 04-21-2015 04:29 PM
Generator Issue? 46fordgal 1947 and Older Ford Trucks 24 04-10-2015 07:22 AM
P1148 code and charging light altruego 6.0L Power Stroke Diesel 7 01-17-2013 06:42 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
